katerinanaza Posted July 23, 2009 Posted July 23, 2009 Hello, I have scale issues. Trying to annotate detail drawing when the leader's text height is set to 1/2" and it works just fine (it adjusts when switching to the paper layout tab). And I used the Mtext for the drawing title underneath, with the text height 1/16" it still looks larger then the leader's and doesn't adjust itself when in paper space although I use the same text style in both cases. I don't know if it's clear enough. I've attached a couple of screen shots as the actual file is to big to upload. Thanks in advance for any ideas. Quote
AlinOz Posted July 23, 2009 Posted July 23, 2009 Looks to me like the Leaders may be set up to be Annotative whereas the Detail notation isn't. If so, I's suggest that you turn off the 'Annotative' in the Leader Style. That way it will just display exactly the same way as it is in Modelspace... Quote
