alternate keys instead of standard
when running autocad somehow my keys have been switched to an alternate keyboard
/ is now é,
' is now è
"ctrl p" is now þ
] is now ç
this goes on for most of the keys especially when holding ctl.
currently I'm running 2 instances of autocad and only of the instances. i figured this might be character set but its selected as western as is my non effected instance of autocad
does anybody know what command or variable got switched and how i can switch it back
autocad 2010 / vista 64
thanks
So this quirky behavior exhibits itself only in AutoCAD and not in Word for instance?
Were you messing around with the DDSTYLE command?
its only in autocad as i type right now /'{} i have no issues
my way around it has been to use other programs and copy the text i need
Did you maybe press the left Alt key (left side of spacebar) and the SHIFT key at the same time?
DDSTYLE hasn't been touched at all. all my drawings come from an existing template
any combination of keys could have been pressed i often type faster than i think
Stylus BT
its been our standard for 5 years now
there isnt anything wrong with the text itself in the drawing. except the fact that its the wrong text.
ill have to leave it for the day as i have field word to go to well see how things are tomorrow ... thanks for the help
So far I've been unable to duplicate the problem (using 2009). Try closing out both instances of AutoCAD (why are you running two individual sessions anyway?) and then open them up again. Problem still there?
Two different drawings. What is the source of each?
