Tekenmeester Posted July 24, 2009 Posted July 24, 2009 Hi, this will be my first post and I would like to say firstly, thanks for the great forum. Now to my problem, I have any image inserted in model space & in paper space I use a viewport to add the image to my drawing, but when I clip an piece of the image off the image still shows as if not cliped althou the vieport border shows it clipped. Quote
StevenMc Posted July 24, 2009 Posted July 24, 2009 first of all welcome to the forum Tekenmeester-not quite sure i understand here, are you using viewport clip (VPCLIP)? if so can you take me through your steps thanks Quote
NBC Posted July 24, 2009 Posted July 24, 2009 If you are trying to clip an image, try using IMAGECLIP Quote
Tekenmeester Posted July 24, 2009 Author Posted July 24, 2009 Tekenmeester-not quite sure i understand here Its in Afrikaans (Language) Any way, yes I am using vpclip,polygonal, then I draw my new border and close the command. Thats all. Quote
Tekenmeester Posted July 24, 2009 Author Posted July 24, 2009 If you are trying to clip an image, try using IMAGECLIP It works when I clip the image itself by when I clip the vieport it doesent work for some reason. Just as info when I insert the same image into a new drawing then vpclip work as it should. I think it must either be some bad objects on my drawing or some system variable. Quote
StevenMc Posted July 24, 2009 Posted July 24, 2009 sorry it wasnt your name i didnt understand it was what tyou were trying to say but its clear now i just ried it on my autocad and i worked so heres how i did it... VCLIP Select viewport to clip: i select viewport Select clipping object or [polygonal] i press enter Specify start point: select start point Specify next point or [Arc/Close/Length/Undo]: i select next point Specify next point or [Arc/Close/Length/Undo]: i select next point Specify next point or [Arc/Close/Length/Undo]: i select next point Specify next point or [Arc/Close/Length/Undo]: i select next point Specify next point or [Arc/Close/Length/Undo]: i type C for close viewport clipped Quote
StevenMc Posted July 24, 2009 Posted July 24, 2009 sorry just seen your other reply must just be an autocad anomaly. i get weird ones like that sometimes Quote
Tekenmeester Posted July 24, 2009 Author Posted July 24, 2009 sorry it wasnt your name i didnt understand it was what tyou were trying to say but its clear now i just ried it on my autocad and i worked so heres how i did it... VCLIP Select viewport to clip: i select viewport Select clipping object or [polygonal] i press enter Specify start point: select start point Specify next point or [Arc/Close/Length/Undo]: i select next point Specify next point or [Arc/Close/Length/Undo]: i select next point Specify next point or [Arc/Close/Length/Undo]: i select next point Specify next point or [Arc/Close/Length/Undo]: i select next point Specify next point or [Arc/Close/Length/Undo]: i type C for close viewport clipped Don't get me wrong here, I have used vpclip many times before without problems, but this only started happening this week with 1 or 2 of my drawing so thats why I think it must be either variable or bad objects on my drawing. Quote
StevenMc Posted July 24, 2009 Posted July 24, 2009 Don't get me wrong here, I have used vpclip many times before without problems, but this only started happening this week with 1 or 2 of my drawing so thats why I think it must be either variable or bad objects on my drawing. sorry tekenmeester, i wasn't questioning your ability if it seemed that way. :wink: yeah sometimes autocad does stuff like that. i had an instance with jaggy lines-all my lines appeared jaggy and it just turned out to be a "glitch". try saving the drawing as something else, then retry. Quote
Tekenmeester Posted July 24, 2009 Author Posted July 24, 2009 Thanks for all the replies. Will let you know if I find something out. Quote
