Hi All
I've been trying my hand at reactors lately.The main question i have for now is; Is it possible to determine which entities you have highlighted without having to run a selection function or something similar?
Thanks
Do you mean which entities are currently selected by the user?
If so, you could use:
(setq ss (cadr (ssgetfirst)))
Lee
Lee
Not quite
When you select an entity and take no action i would like to start a reactor
Well, you could use an object reactor I suppose, using:
:vlr-openedForModify
but I am not sure if it would work or not. :)
Just tested the above theory using:
(defun c:ObjON ()
 (vl-load-com)
 (if (not *Obj)
   (setq *Obj
     (vlr-object-reactor
       (mapcar 'vlax-ename->vla-object
         (mapcar 'cadr (ssnamex (ssget "_X")))) nil
       (list
         (cons :vlr-openedforModify 'ModObj)))))
 (princ))
(defun ModObj (Obj Rea Arg)
 (princ
   (vl-princ-to-string Obj))
 (princ))
It is obvious from this that it doesn't quite fire exactly when you want it to.
I am not sure what else you could try though... :geek:
On second thoughts, this would be something like what you are after:
(defun c:ObjON ()
 (vl-load-com)
 (if (not *Obj)
   (setq *Obj
     (vlr-miscellaneous-reactor nil
       (list
         (cons :vlr-pickfirstModified 'ModObj)))))
 (princ))
(defun ModObj (Reac Args)
 (alert "Selected!")
 (princ))
(defun c:ObjOFF ()
 (if *Obj
     (vlr-remove *Obj)
     (setq *Obj nil)))
 (princ))
Using a Miscellaneous Reactor, with the :vlr-pickfirstModified callback.
