I recently took over some work from the designer, and it seems that when I open their files, some are oriented to north, others to the main part of the roadway, and others along drainage culverts crossing the roadway. When I xref the files into each other they come in matching the drawing I am in. How can I rotate the drawing that I am in so north displays as up?
make sure that your ucs is the world ucs, and if I understand you correctly you need to use the 'plan' command to set the waorld ucs to your current view.
