I'm looking :unsure: for a lisp rutine, to put the area or the perimeter of a polyline, as a leader, but i want it to be dynamic (field) as the polyline changes, the value inside the leader should change.
thank you for being interesed.
  • Replies 29
  • fixo
    8
  • temo
    5
  • dglenn9000
    2
  • filan1a
    2
Posted Images
Give this a try
(defun C:FA  (/ acsp adoc cpt elist en ent fld lead_obj lpt mtx oid osm)
 (vl-load-com)
 (or adoc
     (setq adoc
     (vla-get-activedocument
       (vlax-get-acad-object)
 (if (and
(= (getvar "tilemode") 0)
(= (getvar "cvport") 1)
   (setq acsp (vla-get-paperspace adoc))
   (setq acsp (vla-get-modelspace adoc))
(setq osm (getvar "osmode"))
 (setvar "osmode" 0)
 (while
   (setq ent (entsel "\nSelect pline or hit Enter to exit"))
    (setq en (car ent))
    (if (wcmatch (cdr (assoc 0 (setq elist (entget en)))) "*POLYLINE")
 (setq cpt (trans (cadr ent)1 0)
       lpt (trans (getpoint cpt "\nPick the ending point of leader:") 1 0)
 (setq oID (vla-get-objectid (vlax-ename->vla-object en)))
 (setq fld
	(strcat
	  (strcat "Area = " "%<\\AcObjProp Object(%<\\_ObjId "
		  (itoa oID)
		  ">%).Area \\f \"%lu2%pr2\">%"
		  "\\P")
	  (strcat "Perimeter = " "%<\\AcObjProp Object(%<\\_ObjId "
		  (itoa oID)
		  ">%).Length \\f \"%lu2%pr2\">%"))
 (setq mtx (vlax-invoke
	     acsp 'AddMText lpt 0.0 fld)
 (vlax-put mtx
	   'AttachmentPoint
	   (cond ((> (car cpt) (car lpt))
		  6
		 ((< (car cpt) (car lpt))
		  4
		 (T 4)
 (vlax-put mtx 'Height (getvar "textsize"))
 (setq lead_obj	(vlax-invoke
		  acsp
		  'Addleader
		  (apply 'append (list cpt lpt))
		  mtx
		  acLineWithArrow
 (vlax-put lead_obj 'VerticalTextPosition 0);1
 (setvar "osmode" osm)
(princ "\n Start command with FA ...")
Give this a try
 (vl-load-com)
 (or adoc
     (setq adoc
 (if (and
 (setvar "osmode" 0)
 (while
    (setq en (car ent))
 (setq fld
	(strcat
		  (itoa oID)
		  "\\P")
		  (itoa oID)
 (vlax-put mtx
	   'AttachmentPoint
		  6
		  4
		 (T 4)
		  acsp
		  'Addleader
		  mtx
		  acLineWithArrow
testing it, till now looks fine.
Many thanks
Glad I have helped
Cheers :)
~'J'~
How does the text for the area change when the polyline changes? How can I change the text format? I'm new to the lisp routines
Thanks
Welcome on board, temo!
Not clearly enough what the format you need
Guess you want to add text with particular precision
and units
What the units you use -metric or imperical?
Better yet attach the small screenshot as .jpg file here
Use 'Manage attachment' button below
After you've changed polyline the text should changes
automatically, just use View->Regen in main menu
Hth
~'J'~
The regen command worked...I want to add text in Square Feet instead of Square inches. The numerical value is highlighted, and i want to take that away. How do I do that?
Thanks
Try this expression instead:
(setq fld
	(strcat
		  (itoa oID)
		  ">%).Area \\f \"%pr1%lu2%ct4%qf1 SQ. FT.\">%"
		  "\\P")
		  (itoa oID)
		  ">%).Length \\f \"%lu3%pr1\">%"))
To unhighlight the polyline after regen just hit ESC key
~'J'~
That worked. Instead of the Perimeter displayed can I get the "Handle Id" to show up? Where do you learn this stuff? How do i post an image so I can show what is highlighted?
Try another one:
(setq fld
	(strcat
		  (itoa oID)
		  "\\P")
	  (strcat "Handle ID = " (vla-get-handle (vlax-ename->vla-object en))
To upload something here scroll down this page
and use "Manage Attachments" button
~'J'~
I dont have a "manage attachments" button but I found out that the text will print without the highlighted box around it so i guess it works out. Thanks
Sorry for the bad explanation
After you will press 'Post reply' button, the message window
will be appears and at the bottom of this window you will see
'Additional Options' tab where you can find 'Manage Attachments'
button and other options
Sorry again for my poor english
~'J'~
Its ok. I got it to work, but this is what shows on my screen. The white rectangles where the area is at is the highlighting that I was talking about. It shows up only on the area text. Is there a way to get rid of it?
By any chance do you know how to export the handle id to an access database or excel spreadsheet? I have been trying to figure out a way to do that but no luck so far.
Thanks
To avoid to "highlight" this field just
set FIELDDISPLAY system variable to 0
Accordingly to export data into Access or Excel
I recommend you to start the new thread with this
question
~'J'~
  • 9 months later...
When I use this script, my text comes in way to small. Is there any where in the script to adjust the text size/height?
Thanks
Thanks
Just change this line:
on this one (e.g. set text height to 250.):
(vlax-put mtx 'Height 250.0); -->change text size to suit here
~'J'~
  • 3 weeks later...
Give this a try
 (vl-load-com)
 (or adoc
     (setq adoc
 (if (and
 (setvar "osmode" 0)
 (while
    (setq en (car ent))
    (setq fld
       (strcat
             (itoa oID)
             "\\P")
             (itoa oID)
    (vlax-put mtx
          'AttachmentPoint
             6
             4
            (T 4)
             acsp
             'Addleader
             mtx
             acLineWithArrow
hi..it is very interesting..thanks...any solution to remove the perimeter the "TXT"
Area = 244.86
Perimeter = 62.89
Area = 244.86 sq.m
thank you..
oliver
I would have said this - but untested:
(defun c:fa  (/ acsp adoc cpt elist en ent fld lead_obj lpt mtx oid osm)
 (vl-load-com)
 (or adoc
     (setq adoc
 (if (and
 (setvar "osmode" 0)
 (while
    (setq en (car ent))
    (setq cpt (trans (cadr ent) 1 0)
    (setq oid (vla-get-objectid (vlax-ename->vla-object en)))
    (setq fld
       (strcat
         (strcat "%<\\AcObjProp Object(%<\\_ObjId "
             (itoa oid)
             "\\P")
             (itoa oid)
            acsp 'addmtext lpt    0.0 fld)
    (vlax-put mtx
          'attachmentpoint
             6
             4
            (t 4)
    (vlax-put mtx 'height (getvar "textsize"))
             acsp
             'addleader
             mtx
             aclinewitharrow
    (vlax-put lead_obj 'verticaltextposition 0) ;1
Fixo, is there a certain version requirement for this LISP?
I just seem to get this return:
