Hey guys,
Is there a way I could easily get the length of the polyline into a variable in this code? What I would like to is determine if the length is between certain values using if statements then edit the label to indicate whether the length is less than or greater than a certain threshold. Any thoughts?
Thanks,
Dave
  • Replies 29
  • fixo
    8
  • temo
    5
  • dglenn9000
    2
  • filan1a
    2
Posted Images
Hey guys,
Thanks,
Dave
This should help you with the answers you need...
(defun c:Test (/ o)
 (and (setq o (car (entsel "\nSelect LWPolyline: "))) ; select
      (setq o (vlax-ename->vla-object o)) ; convert to vla-object
      (eq (vla-get-objectname o) "AcDbPolyline") ; verify object type
      (alert (strcat "Area: "
                     (vl-princ-to-string (vla-get-area o)) ; get area
                     "\nLength: "
                     (vl-princ-to-string (vla-get-length o)) ; get length
             ) ;_ strcat
      ) ;_ alert
 ) ;_ and
) ;_ defun
Thanks a lot Alan, I combined Fixos script with yours and it is working well.
Glad you got it to work. :)
  • 6 years later...
Hello.
I've been using a customized version of this lisp for a long time with Autocad 2011.
Now I have passed to R2013 and I get this error message:
; warning:AutoCAD type library load failed: "Error during the upload of the DLL library"
; error: no function definition: VLAX-GET-ACAD-OBJECT
I know this is a common problem for that function but I haven't found the solution.
So, I'd like to know if someone can tell me how to fix it or if someone can update my lisp that I paste here below.
Many thanks in advance.
 (defun c:fa  (/ acsp adoc cpt elist en ent fld lead_obj lpt mtx oid osm)
 (vl-load-com)
 (or adoc
     (setq adoc
        (vla-get-activedocument
          (vlax-get-acad-object)
 (if (and
   (= (getvar "tilemode") 0)
   (= (getvar "cvport") 1)
   (setq acsp (vla-get-paperspace adoc))
   (setq acsp (vla-get-modelspace adoc))
 (setq osm (getvar "osmode"))
 (setvar "osmode" 0)
 (while
   (setq ent (entsel "\nSelect pline or hit Enter to exit"))
    (setq en (car ent))
    (if (wcmatch (cdr (assoc 0 (setq elist (entget en)))) "*POLYLINE")
    (setq cpt (trans (cadr ent) 1 0)
          lpt (trans (getpoint cpt "\nPick the ending point of leader:") 1 0)
    (setq oid (vla-get-objectid (vlax-ename->vla-object en)))
    (setq fld
       (strcat
         (strcat "%<\\AcObjProp Object(%<\\_ObjId "
             (itoa oid)
             ">%).Area \\f \"%lu2%pr2%ps[Mq. ,]%ds44%ct8[0.0001]\">%"
             "\\P"))
    (setq mtx (vlax-invoke
            acsp 'addmtext lpt    0.0 fld)
    (vlax-put mtx
          'attachmentpoint
          (cond ((> (car cpt) (car lpt))
             6
            ((< (car cpt) (car lpt))
             4
            (t 4)
    (vlax-put mtx 'height (getvar "textsize"))
    (setq lead_obj    (vlax-invoke
             acsp
             'addleader
             (apply 'append (list cpt lpt))
             mtx
             aclinewitharrow
    (vlax-put lead_obj 'verticaltextposition 0) ;1
 (setvar "osmode" osm)
(princ "\n Start command with FA ...")
  • 1 year later...
Give this a try
(defun C:FA  (/ acsp adoc cpt elist en ent fld lead_obj lpt mtx oid osm)
 (vl-load-com)
 (or adoc
     (setq adoc
 (if (and
 (setvar "osmode" 0)
 (while
    (setq en (car ent))
 (setq cpt (trans (cadr ent)1 0)
 (setq oID (vla-get-objectid (vlax-ename->vla-object en)))
 (setq fld
	(strcat
	  (strcat "Area = " "%<\\AcObjProp Object(%<\\_ObjId "
		  (itoa oID)
		  ">%).Area \\f \"%lu2%pr2\">%"
		  "\\P"))
	     acsp 'AddMText lpt 0.0 fld)
 (vlax-put mtx
	   'AttachmentPoint
		  6
		  4
		 (T 4)
 (vlax-put mtx 'Height (getvar "textsize"))
		  acsp
		  'Addleader
		  mtx
		  acLineWithArrow
 (vlax-put lead_obj 'VerticalTextPosition 0);1
Can this multiply the area by a factor (i.e. 3.62) and return that answer instead?
I am not worried about units at this point.
Also the can the precision be set to match the current dimension style in use? or just set to round to then whole number w/o decimals?
thanks for the help!
  • 7 years later...
 (vl-load-com)
 (or adoc
     (setq adoc
 (if (and
 (setvar "osmode" 0)
 (while
    (setq en (car ent))
 (setq fld
	(strcat
		  (itoa oID)
		  "\\P")
	  (strcat "Perimeter = " "%<\\AcObjProp Object(%<\\_ObjId "
		  (itoa oID)
		  ">%).Length \\f \"%lu2%pr2\">%"))
 (vlax-put mtx
	   'AttachmentPoint
		  6
		  4
		 (T 4)
		  acsp
		  'Addleader
		  mtx
		  acLineWithArrow
Hello how can i change the height value if i use millimeter drawing
Hello,
Can you help me because im using millimeter drawing when i use this lisp the value and text is small, how can i change the value height in millimeter.
thank you.
Polylin Length FA-L.LSP
The height of the text you can change with the "style" command.
There you can change the default value of the text-style that is applied.
