I'm trying to do a floor plan. When I go to polylines and put two together and do their width, it comes up with them touching but leaving a little space between two of the corners (circled in red). I simply can't make it look like one polyline.
Well that was an easy fix. The answer was right in front of me the whole time. All I had to do was fillet them and put radius to 0.
If you had used PEDIT to join the two polylines, you would not have had the problem.
In fact, by using Fillet, you have actually joined the two polylines. :D
I realized that as I went to the fourth corner (just trying it out).
Thanks for that PEDIT command tip.
