kippax Posted July 27, 2009 Author Posted July 27, 2009 And you tried resetting the rotation angle? Not sure where that is... nor why its changed in the first place Quote
ReMark Posted July 27, 2009 Posted July 27, 2009 Are you speaking of single line or multi-line text? Quote
ReMark Posted July 27, 2009 Posted July 27, 2009 I thought that after putting text in at an angle other than "0" MTEXT would reset itself the next time it was used. Anyway, when you use MTEXT you're prompted to pick the first corner. Make the pick. But before you specify the opposite corner take a look at your command line at the bottom of the screen. There is an option for Rotation that allows you to specify the angle. Type "R" (for Rotation), press Enter, specify the angle, press Enter then specify the opposite corner. After creating your text it should be depicted at the angle you typed in. Quote
kippax Posted July 27, 2009 Author Posted July 27, 2009 thats great, all sorted..... many thanks.. Quote
