DMcNiel Posted July 27, 2009 Posted July 27, 2009 First, I am very new to writing lisp:unsure: I have a small lisp that I use to change the z value of a lwpolyline and I have a hyperlink set up to show me that value when I hover over the lwpolyline. I am not actually linking to anything. So my question is, can I get rid of the text in the hyperlink box that says "Ctrl+click to follow link" ? ;Zdepth lisp ;Moves a single selected polyline Z coordinate to user specified elevation ;Created 7/9/09 DJM ( defun c:RX (/ a x b c d a1 ) (setvar "cmdecho" 1) (setq a(entget (car (entsel)))) (setq x(cdr (assoc -1 a))) (setq b(assoc 38 a)) (setq c(getreal "\nENTER NEW Z VALUE")) (setq d(cons (car b ) c)) (setq a1(subst d b a)) (entmod a1) (setq c(rtos c 2 3)) (command "-hyperlink" "i" "o" x "" "current drawing" "none" c) ) Quote
The Buzzard Posted July 27, 2009 Posted July 27, 2009 First, I am very new to writing lisp:unsure: I have a small lisp that I use to change the z value of a lwpolyline and I have a hyperlink set up to show me that value when I hover over the lwpolyline. I am not actually linking to anything. So my question is, can I get rid of the text in the hyperlink box that says "Ctrl+click to follow link" ? ;Zdepth lisp ;Moves a single selected polyline Z coordinate to user specified elevation ;Created 7/9/09 DJM ( defun c:RX (/ a x b c d a1 ) (setvar "cmdecho" 1) (setq a(entget (car (entsel)))) (setq x(cdr (assoc -1 a))) (setq b(assoc 38 a)) (setq c(getreal "\nENTER NEW Z VALUE")) (setq d(cons (car b ) c)) (setq a1(subst d b a)) (entmod a1) (setq c(rtos c 2 3)) (command "-hyperlink" "i" "o" x "" "current drawing" "none" c) ) I only see the Z length or thicnkness and nothing else. I do not see the text in the hyperlink box you mention. I also notice whatever value entered for the hyperlink will be incorrect if the z value of the object is actually different. Quote
DMcNiel Posted July 27, 2009 Author Posted July 27, 2009 Thanks for taking a look. It may be a hyperlink setting that either shows or doesn't show that text. The hyperlinked value is whatever value is typed in for the z elevation movement, so the hyperlinked value should change whenever the z elevation changes, when using this routine. Ohh, by the way I am using autocad 2008 on a WIN XP system. Not sure if that makes any difference but I didn't mention it earlier. Quote
The Buzzard Posted July 27, 2009 Posted July 27, 2009 Thanks for taking a look. It may be a hyperlink setting that either shows or doesn't show that text. The hyperlinked value is whatever value is typed in for the z elevation movement, so the hyperlinked value should change whenever the z elevation changes, when using this routine. Ohh, by the way I am using autocad 2008 on a WIN XP system. Not sure if that makes any difference but I didn't mention it earlier. Originally I tested it in 2004. Since you brought up the idea about version, I tested it also now in 2009 and yes, I see the message now. Not sure at this stage how to get rid of it. I would review the command and any associated variables to see if this can be changed. If I find something first, I will bring it to your attention. Also take a look at this link: http://www.cadtutor.net/forum/showthread.php?t=36273 It does something along the lines of what I think your trying to do. I am not sure exactly, But give it a look anyway. Quote
Lee Mac Posted July 27, 2009 Posted July 27, 2009 I'm not sure that you can remove the Ctrl+click message, but here is an alternative method: [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:rx [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ent Obj zVal[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entsel[/color][/b] [b][color=#ff00ff]"\nSelect LWPolyline: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=DARKRED]'[/color][/b]ENAME [b][color=RED]([/color][/b][b][color=BLUE]type[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"AcDbPolyline"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ObjectName[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Object is not an LWPOLYLINE **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]t[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Nothing Selected **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] zVal [b][color=RED]([/color][/b][b][color=BLUE]getdist[/color][/b] [b][color=#ff00ff]"\nEnter New Z Value: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-put-Elevation[/color][/b] Obj zVal[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-add[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Hyperlinks[/color][/b] Obj[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-princ-to-string[/color][/b] zVal[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] A few pointers, if I may: Use more descriptive names for your variables, it makes the code 10x easier to read and understand - especially when you are first learning. Use conditional statements, such as IF, or a WHILE loop, to allow for null user input, or a missed click - else these will result in an error. When using the "command" function, include the language compatibility prefixes, i.e.: (command "_.line" (list 0 1 0) (list 2 3 4) "") Well done for localising your variables, many new LISP'ers miss that, and it can cause a lot of trouble.. If you have any further questions, just ask Lee Quote
DMcNiel Posted July 27, 2009 Author Posted July 27, 2009 Thanks for the pointers, I like the part about being more descriptive with the variables. With the code you have there, when I edited the Z elevation the first time the hyperlink was correct. When I used the same routine to change the elevation again, the hyperlink info didn't change. And , of course, the "Ctrl + click to follow link" was still there. Thanks for the help. Quote
Lee Mac Posted July 27, 2009 Posted July 27, 2009 I hadn't allowed for re-editing of hyperlinks, will update the code. And, yes, as I stated in my previous post, I don't think you can remove the Ctrl+click message. Lee Quote
Lee Mac Posted July 27, 2009 Posted July 27, 2009 Code updated, assuming 1 hyperlink per object: (defun c:rx (/ ent Obj zVal) (vl-load-com) (while (progn (setq ent (car (entsel "\nSelect LWPolyline: "))) (cond ((eq 'ENAME (type ent)) (if (not (eq "AcDbPolyline" (vla-get-ObjectName (setq Obj (vlax-ename->vla-object ent))))) (princ "\n** Object is not an LWPOLYLINE **"))) (t (princ "\n** Nothing Selected **"))))) (if (setq zVal (getdist "\nEnter New Z Value: ")) (progn (vla-put-Elevation Obj zVal) (if (zerop (vla-get-Count (setq hlnk (vla-get-Hyperlinks Obj)))) (vla-add hlnk (vl-princ-to-string zVal)) (vlax-for lnk hlnk (vla-put-url lnk zVal))))) (princ)) Quote
