I am attempting to convert a 3D solid, created and exported from Revit 2010 (as a ACIS solid) to lines in AutoCAD. I have tried exploding, but the solid becomes a region and the region will not explode. Xedges only gives me the linear segments (no curves). Any thoughts as to why these techniques won't work?
3D Slab 2010 acis solid.dwg
Per AutoDesk:
"Autodesk Revit can import and export models to DXF™ and DWG formats."
Why was it necessary to export your 3D Revit solid as an ACIS solid to get it into AutoCAD? Just curious. I have no experience with Revit.
Well the final destination for this file is survey software that reads in AutoCAD R14 DWGs. What I need to do is take solids out of Revit, and convert the edges or intersections to points and lines with elevation data intact. AutoCAD is the middleman.
Thank you for taking the time to educate me. Much appreciated.
Re-reading your post, I realized I didn't fully answer your question. I could have exported out of Revit as a polymesh, an ACIS solid or a ACA object as well. Those are the 3 options when exporting a 3D object out of Revit 2010 to AutoCAD DWG.
