Can't seem to get this to work exactly right.
In the ancient(!) routine below, that I use at work (but don't know enough yet to clean it up), there's the line:
(command "DDATTE" bname) In red in the code block below
which opens the attribute editor for a just-created region so attribute data can be input.
I happened upon an excellent replacement for DDATTE/ATTEDIT by CAB called MyAttEdit.
It was easy to modify to show more attribute lines, making it much more useful than ATTEDIT, so I thought I'd try to make it part of the program.
The LSP and the DCL are in the support path and the LSP is also in the acad.doc file.
As a standalone program it works great, but when I try to call it with this routine. I get the error "Unknown command MyAttEdit" and main routine exits.
Using the line (C:MyAttEdit) gets it running, of course, but it's no longer associated with, or connected to, or acting on "bname".
Need to retain that association.
I'm missing something very basic, I believe, but my brain doesn't want to cooperate.
I've read and tried to implement the ideas from here and here, but no joy.
Can someone please point me in the right direction?
Thanks,
Steve
;* DATE 05/20/93
;*REVISED 08/08/00
(setvar "REGENMODE" 1)
;* Function: DXF (Generic)
;* Created by: Rocky W. (3/10/94)
;* Parameters in:
;* Returns:
;* Comments: takes an integer DXF code and an entity list, and
;*    returns the data element of the associated pair.
(defun err (s)
  (if (not (MEMBER s '("console break " "Function cancelled")))
     (princ (strcat "\nERROR: " s))
     ;(command "_.U")
     ;(COMMAND "_.redraw")
  (setq *error* olderr)
(defun DXF (code elist)
  (cdr (assoc code elist))
;* Function:C:Hotspot
;* Used by:DSD group
;* Parameters in:
;* Returns:
;* Comments:Used to semi automate the process of assigning attributes to
;*          blocks and regions in a drawing.
;*          region is update by autobox for exiting region with new cords.
(defun C:AUTOROCK(/ olderr)
(c:BOXQA) ; outlines existing attributed regions (helps track progress across the drawing)
  (command "ucs" "w");this sets the UCS back to World
  (if (tblsearch "LAYER" "NOPLOT")
     (command "_.Layer" "_S" "NOPLOT" "U" "NOPLOT" "")
     (Progn
        (command "_.Layer" "_M" "NOPLOT" "_C" "MAGENTA" "NOPLOT" "_LT" "CONTINUOUS" "NOPLOT" "U" "NOPLOT" "")
  (setq rin nil
     mrin ""
     ulsize nil
     lrsize nil
     textdatin ""
     textdatout ""
     var (getvar "CMDECHO")
     atvar (getvar "AFLAGS")
     a2 nil
     atblk 1
     dname (getvar "dwgname")
     strleg (strlen dname)
     strleg1(- strleg 4)
     dpre  (getvar "dwgprefix")
  drawname (substr dname 1 strleg1))
  (setq olderr *error* *error* err)
  (setq cmdech var)
  (setvar "AFLAGS" 1)
  (autobox2)       ;* call function
  ; draw box from selection
  (setq p2 (list (car ul) (cadr lr) )) ;lr corner
  (setq p4 (list (car lr) (cadr ul) )) ;lr corner
  ;function to draw colored vectored region
  (grdraw ul p2 7 1)
  (grdraw p2 lr 7 1)
  (grdraw ul p4 7 1)
  (grdraw p4 lr 7 1)
  (prompt "\nPick all items that make up unit...")
  (setq ss2 (ssget))
  (setq a (dxf 2 (entget (ssname ss2 0))))
  (if (/= a nil)
     (setq a2 (tblsearch "BLOCK" a))     ;* true if a is a block
     (progn                               ;* false
        (setq xxx  (sslength ss2))   ;loop counter
        (setq cxxx 1)
        (setq textdat "")
        (while (<= cxxx xxx)
           (setq dat1 (entget (ssname ss2 (- cxxx 1))))
           (setq txttype (cdr (assoc 0 dat1)))
           (if (= txttype "TEXT")
              (progn                    ;* progn start
                 (setq txt1 (dxf 1 dat1))  ;if false
                 (setq textdat (strcat textdat txt1 " "))
                 (setq cxxx (+ 1 cxxx))
              )                         ;*progn end
           ) ;* endif
        ) ;while end
     ) ;*progn end
  ) ;*endif block check
  (if rin ()(setq rin ""))
  (setq dscord (dxf 10 (entget (ssname ss2 0))))     ;* get insert point
  (setq dscord (list (- (car dscord) 0.05) (-(cadr dscord) 0.05)))
  (setq bname (ssname ss2 0))
  (if (and (/= a nil)(= (sslength ss2) 1)(/= a2 nil))
        (setq en bname)
        (setq ed (entget en))
        (while (/= "SEQEND" (dxf 0 ed))                     ;*** while 2
           (setq en (entnext en))
           (setq tag (dxf 2 ed))
           (setq val (dxf 1 ed))
           (if (/= "SEQEND" (dxf 0 ed))                       ;*** if 2
              (progn                                            ;*** progn 2
                 (if (= "BOXSIZE" TAG)                                ;*** if 3
                    (progn                                          ;*** progn 3
                       (setq  ttval (read val))
                       ;*      (strcase ttval)
                       (if (/= ttval BSIZE)
                             (setq ed (subst (cons 1 BSIZE)(assoc 1 ed) ed ))
                             (entmod ed)
                             (entupd en)
                             (PRINC (STRCAT "BOXSIZE CHANGED  " BSIZE " " VAL "   "))
                    )                                                ;*** progn 3
                 )                                                 ;*** endif 3
              )                                                  ;*** progn 2
           )                                                   ;*** endif 2
        )                                                    ;*** while 2
[color=red];;;[/color]
[color=red];;;   [b]In place of this line, I would like to call CAB's routine MyAttEdit[/b][/color]
[color=red]  (command "DDATTE" bname)[/color]
[color=red];;;   [/color]
        (command "attdef" "" "NAME" "Enter NAME." textdat dscord "")
        (setq nameattr1 (entlast))
        (command "attdef" "" "RIN" "Enter RIN." RIN dscord "")
        (setq nameattr2 (entlast))
        (command "attdef" "" "BOXSIZE"  "Enter boxsize.     " bsize dscord "")
        (setq nameattr3 (entlast))
        (command "attdef" "" "MRIN"  "Enter SCLSIS Rin." mrin dscord "")
        (setq nameattr4 (entlast))
        (setq CurLayer( getvar "clayer"))
        (command "attdef" "" "CURRENTLAYER" "Enter Current Layer." "NOPLOT" dscord "")
        (setq nameattr5 (entlast))
        (command "attdef" "" "SHAPE" "Enter Object Shape Type." "R" dscord "")
        (setq nameattr6 (entlast))
        (command "attdef" "" "OBJTYPE" "Enter Object Type." "EQ" dscord "");MOD BY JDR 8/8/00
        (setq nameattr7 (entlast))
        (setq bname   (itoa atblk))
        (while (tblsearch "BLOCK"   (strcat drawname "$ECC$" bname))
              (setq atblk (+ atblk 1)
                 bname  (itoa atblk))
       (setq bname (strcat drawname "$ECC$" bname))
         (command "block" bname dscord  nameattr1 nameattr2 nameattr3 nameattr4 nameattr5 nameattr6 nameattr7 )
         (setq count 0
           emax (sslength ss2)
         (while (< count emax)
           (command (ssname ss2 count))
           (setq count (1+ count))
         (setvar "ATTREQ" 1)
         (setvar "ATTDIA" 1)
         (command "" "insert" bname dscord "1" "1" "0" )
 (command "redraw") ;clears existing region outlines so NOID regions will display
(NOID) ;* call function to display "neglect" regions
(defun AUTOBOX2()
  (setq bsize nil)
  (setq ul (getpoint "Pick UL corner: ")
  lr (getcorner ul "Pick LR corner: "))
  (setq bsize (strcat "("(rtos (car ul) 2 6) " " (rtos (cadr ul) 2 6) " " (rtos (car lr) 2 6) " " (rtos (cadr lr) 2 6)")" ))
);AUTOBOX2
;;This part written by LeeMac (cadtutor.net) 14 May 2009. Thanks, Lee.
(defun NOID (/ ss attLst Box ul lr); To outline regions with no ID
(vl-load-com)
(if (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1))))
     (foreach Obj (mapcar 'vlax-ename->vla-object
                    (mapcar 'cadr (ssnamex ss)))
       (setq attLst nil)
       (foreach att (vlax-safearray->list
                      (vlax-variant-value
                        (vla-getAttributes Obj)))
         (setq attLst (cons (cons (vla-get-TagString att)
                                  (vla-get-TextString att)) attLst)))
       (if (and (assoc "RIN" attLst)
                (eq "" (cdr (assoc "RIN" attLst)))
                (setq Box (assoc "BOXSIZE" attLst)
                      Box (read (cdr Box))))
           (setq ul (list (car Box) (cadr Box))
                 lr (list (caddr Box) (cadddr Box)))
           (grvecs (list 1 lr (list (car lr) (cadr ul))
                         1 ul (list (car lr) (cadr ul))
                         1 lr (list (car ul) (cadr lr))
                         1 ul (list (car ul) (cadr lr)))))))))
You may need to tweak CABs routine to accept an argument, or make the variable that is the block object global :)
Thanks. I'll try that.
Steve
in place of that command try this
(sssetfirst nil bname)
(C:MyAttEdit)
Bill, don't know what is wrong, but that doesn't seem to work here.
I get the following error,
ERROR: bad argument type: lselsetp
That is because "bname" is an entity not a Selection set.
Nothing I tried could get it to work. I'll have to settle for a two-step operation.
Thanks anyway, guys,
Steve
If you post CAB's routine, or a link to it, I'm sure I could help :)
Ok Steve, All you need to do is to comment the main function defintion at the top, down to the function header, outlined in "+" symbols.
Then, in your routine, just put:
(myattedit bname nil nil)
in place of your red code.
(make sure that CAB's code is loaded when running your code).
Lee
Please excuse the delayed response, but I had to be at work to test.
I was only able to get that solution to work on existing regions. When establishing new regions, ATTEDIT still runs.
Looking a little deeper, I noticed both routines have a variable called bname, but I don't know enough to figure if this may be a contributing factor.
However, that it now works on existing regions is a good thing, and I thank you for that.
Steve
Steve
Glad you got it sorted - well, at least partly.
As for the variable clash, try it with a different variable name in your routine and see if it makes a difference. As "bname" is localised in CAB's routine and will hence be set to nil after completion.
Lee
