I have a very simple bracket drawn up in model space at 1:1. I'm using Imperial units. When I move to paperspace I cannot get the hidden lines to appear. My LTS in model space is set to 0.3 and the hidden lines show perfect. But when I go to PS I cannot get them to show. Is there a way to calculate what my LTS should be in PS to show these lines? Is there an option that could be suppressing them? My viewscale in PS is 1/4" = 1"
Try setting it to zero... Then regenall
It didn't work, should I have my paperspace LTS set to match my model space or set it to 1?
If you can attach the file... I can fix it for you.
Sorry I don't have a way to attach a file.
Try setting
Msltscale=1
Psltscale=1 (needs to be set in each layout tab)
Ltscale=1 (or your preference)
MSLTSCALE does not work in my version of CAD ('06). And everything else is set as requested. Still not working.
I figured, your problem should be an easy fix, but I'm better at doing than trying to explain... In other words, if you could upload the file I'm sure I could fix the issue. Where's Remark when you need him, I'm sure he could spill out the solution in a second.
can you provide me with an email address and I'll email it to you?
Not such a great idea, posting your email address on the www forums.
Do you like spam? :oops:
Thanks for looking out for me dad!!
