How Do I Make An Attribute From Scratch. I Want To Make A Block That I Can Insert And Do A Few Things To Before It Is Inserted. Like Scale, Rotate, Etc.
Any Help Would Be Great!
Thank You!!
Making Attributes from scratch depends upon which method you want to use, VL or AutoLISP.
I find VL easier, using vla-addAttribute, adding the attribute to either the Model/Paper space collection, or immediately to the block definition itself.
Alternatively, you can use entmake to create the definition.
Here is a helpful thread:
http://www.cadtutor.net/forum/showpost.php?p=253737&postcount=16
The above will convert text to attribute (making the attribute using entmake).
Lee
