Hi All,
been using Sheet Sets with a moderate degree of success to plot some jobs, but would also like (ie, strongly prefer) to be able to use the publish command.
However, I get the error of device not found when attempting this. After some research, seems I need the DWF6 ePlot.pc3 file, which I don't seem to have. Using the add-a-plotter wizard to try and recreate this, this doesn't seem to even be an option for us. Seems one way to do this is to reinstall AutoCAD, which I find scary, and possibly unnecessary; we have two computers here, neither have/can create this file.
Other than reinstalling, is there some way to add "DWF6 ePlot.pc3"? Thanks so much in advance!
Oh, forgot: Usiing ADT 2005
simply rename the attached file extension to pc3 and place in the same location as all your other pc3 files
DWF6 ePlot.txt
This works very nicely. Any ideas why this was unavailable?
Still worried a bit as I now need to make sure everything plot's correctly (an issue sometimes with our HP 750c) and also we seem to have corruption issues with our pc3 files (no idea why...very frustrating.) Guess I'll have to play around with this a bit and keep a copy in a very safe location!
NBC, thank you very much!:D
To be honest, I have no idea why that file was unavailable previously.
Hopefully the file I uploaded will assist you in your goals.
  • 2 years later...
Just used your attached file, thanks for that. Got me out of a situation with the boss.
  • 4 years later...
Is anyone having problems with the DWF6 plot.pc3 driver with AutoCAD 2015 for Mac?
