Hello, all,
I know ordinarily objects on frozen layers can't be purged - but what if that's all I want to get rid of? I've got tons of frozen layers that all have to be purged out, and if I just unfreeze them all - I'll lose track! Is there any quick and easy way to tell CAD to just purge everything I can't see? (Or perhaps there's a way to flip the layer states?)
Any ideas? Thanks so much!
Heduanna
  • Replies 20
  • alanjt
    9
  • hugo1099
    6
  • Heduanna
    2
  • chelsea1307
    2
How about copy/paste what you see on the screen into a new drawing? Or zoom to extents, start the WBLOCK command and when prompted to "select objects" make a windows selection for the whole screen.
KISS - you're absolutely right! Thanks!
this will delete and purge all frozen layers
;delete all frozen layers
(defun c:delfrz (/ lays lay layname ss index lock_state)
(command "undo" "begin")
 (setq lays (vla-get-layers
              (vla-get-activedocument (vlax-get-acad-object))
 (vlax-for lay lays
   (if (eq (vla-get-freeze lay) :vlax-true)
       (setq layname (vla-get-name lay))
       (if (not (wcmatch layname "*|*"))
           (if
             (setq ss (ssget "_X" (list (cons 8 layname))))
                (vla-put-freeze lay :vlax-false)
                ;; NOT NEEDED (vla-put-layeron lay :vlax-true)
                (setq lock_state (vla-get-lock lay))
                (vla-put-lock lay :vlax-false)
                ;; NOT NEEDED (vla-regen (vla-get-activedocument (vlax-get-acad-object))acactiveviewport)
                (setq index (sslength ss))
                (while (>= (setq index (1- index)) 0)
                  (vla-delete (vlax-ename->vla-object (ssname ss index)))
          (command "-layer" "t" layname "")
          (command "-purge" "la" layname "n")
                (if (eq lock_state :vlax-true)
                  (vla-put-lock lay :vlax-true)
              (princ (strcat "Nothing on layer " layname))
         (princ (strcat "Frozen or off xref layer skipped - " layname))
(command "undo" "end")
With old drawings or drawings from other sources, I like this approach. You get rid of all objects you don't need and you can start with your own settings.
  • 1 year later...
I'm just getting into Scripts, and can't get this to work. I copied and pasted it into notepad, then saved it as a .SCR, and dropped it into the file. The script ran, and in the command line it left "(_> )" , when I hit enter, nothing happened, and all of my frozen objects were still there? Any suggestions
 (vlax-for lay lays
           (if
I think you just missed a paren when you were copy/pasting.
However, give this one a try, should yield much better results...
;;; Delete frozen layers
;;; Alan J. Thompson, 10.15.09
(defun c:DelFrz (/ #Doc #SS)
 (vl-load-com)
 (vlax-for x
           (vla-get-layers (setq #Doc (vla-get-activedocument (vlax-get-acad-object))))
   (if (and (eq (vla-get-freeze x) :vlax-true)
            (not (wcmatch (vla-get-name x) "*|*"))
       ) ;_ and
       (vla-put-freeze x :vlax-false)
       (vla-put-lock x :vlax-false)
       (if (setq #SS (ssget "_X" (list (cons 8 (vla-get-name x)))))
         (progn (vlax-for i (setq #SS (vla-get-activeselectionset #Doc))
                  (vl-catch-all-apply 'vla-delete (list i))
                ) ;_ vlax-for
                (vla-delete #SS)
         ) ;_ progn
       ) ;_ if
       (vl-catch-all-apply 'vla-delete (list x))
     ) ;_ progn
   ) ;_ if
 ) ;_ vlax-for
) ;_ defun
Same thing. I'm gonna do more research on Scripts before wasting anyones time, I'll post again if i'm still having trouble
Thanks
 (vl-load-com)
 (vlax-for x
       ) ;_ and
                ) ;_ vlax-for
                (vla-delete #SS)
         ) ;_ progn
       ) ;_ if
     ) ;_ progn
   ) ;_ if
 ) ;_ vlax-for
) ;_ defun
Thanks
Post your script.
You could just place the routine in a support path put this in your script:
(and (load "Delfrz.lsp" nil) (c:DelFrz))
I've attached the txt file and the scr file
Try something like this:
(defun DelFrz (/ #Doc #SS)
 (vl-load-com)
 (vlax-for x
       ) ;_ and
                ) ;_ vlax-for
                (vla-delete #SS)
         ) ;_ progn
       ) ;_ if
     ) ;_ progn
   ) ;_ if
 ) ;_ vlax-for
(DelFrz)
I'm confused though, why are you executing it as a script if that's all there is. This is a lisp routine.
You need to save it as a .lsp not a .scr and then load it and execute by DELFRZ
Sounds like I need to do much more research, this is all new to me. Thanks for all of your help
Ask all the questions you need. :)
Review the FAQ section, it will give you a lot of the information you need.
I've always been a standard construction guy turned CAD guy, I came across this site and finally reallized how much more I can be doing. I'll be asking very shortly. Thanks again
:) No problem.
Got one for ya. I've been trying to string together a bunch of different commands for a Script, if I am doing a function, such as LINE, that keeps going until you hit cancel. How do I cancel it in my text file so I can begin another type of command? I've tried a number of commands, esc, cancel... Any suggestions?
you should start a new thread with a new question, you will get more views that way and a faster answer. I dont write scripts but you can end the line command with enter
These are Lisps not Scripts.
Give this a try:
(defun c:test (/)
 (command "_.line")
 (while (not (zerop (getvar "cmdactive")))
   (command PAUSE)
 ) ;_ while
) ;_ defun
