Is it at all possible to insert blank lines in LISP?
Do you mean a text entity with just spaces? If so 'Yes' you can but I wouldn't recommend it. -David
If you are referring to the code itself, then LISP does not care for spaces or extra lines, and will interpret the code that is written. :)
What purpose would you like these blanks lines to serve?
\n
did try to put that alone & be checky but i need 10 words
