DVDM Posted July 31, 2009 Posted July 31, 2009 We have a company CUI, and I'd like to add an item to the menu that simply opens one specific drawing, for example: H:\Drawings\Library\123.dwg (basically a master template containing a lot of blocks and other elements.) I thought using a macro like ^C^C-filedia;0;open;"H:\Drawings\Library\123.dwg"; would do the trick, but soon discovered it's not that simple. Anyone implimented something like this before? Quote
flowerrobot Posted July 31, 2009 Posted July 31, 2009 Sorry no go there with the marcro, (looks fine in my eyes). Would suggest setting filedia back to 1 A lisp is quite easy to do there. except it would need to be called from the command line Quote
dbroada Posted July 31, 2009 Posted July 31, 2009 try replacing the backslashes with forward slashes. Quote
