How can i find all wipe outs and text masks in a dwg at once with out turning the wipe out frames on?
Thanks for the help!!
Hi,
This should do it.
(setq test (ssget "X" '((0 . "WIPEOUT"))))
Have a good one.
Shawndoe
And maybe use of (sssetfirst nil test) to highlight :)
PS> don't forget language compatibility:
(sssetfirst nil (ssget "[color=Red]_[/color]X" '((0 . "WIPEOUT"))))
Thank You Both.... I Will Try Them Out!
wait... are those lisps? it didn't work!!
hahahaha Ok I got it.... i have to type all that. Thank you... it worked great!! you both rock!!
Yes, they are LISP statements, and perhaps need to be included in a function definition.
Actually I don't use functions for custom selection sets. I use the code just as I posted it. Then when I am asked for a selection set by a command I just hand it "!test".
This is also a good way to make selection sets of objects that you can recall as needed. Just remember that these are global variables and will stay in your drawing until you restart it or set the variable back to nil.
As for language compatability, I might worry about that if:
(a) I had anybody who I write code for request it
(b) If I were providing more then a snippet of code.
© I also don't do language compatablity when providing LISP arguments. These are not displayed at the command line anyway so nobody will see them.
Have a good one.
Shawndoe
No worries Shawn, I realise I was being a little petty - I just like things perfect :wink:
