Heres my problem....
When I start a project there are many blocks that I have to insert depending on the job criteria. This can be a very tedious process as you all know. I am wondering if there is a way out there to use a dialogue box to select certain criteria like block names. then insert these blocks automatically into my drawing all at onxce instead of going through the insert command 10 times....??
Any ideas on this?
Thanks in advance you people and this site help me immensley...:)
Any ideas on this?
Not sure if i understand the task but couldn't you just insert a template with all the blocks you're likely to use and copy / paste to suit.
Are they attribute blocks
Are they always being inserted in the same place?
If so, a template (as Ollie says) is your best bet I would think :)
