muck Posted August 4, 2009 Posted August 4, 2009 Version 2009 I have used "Export layout to Model" to create a file in model space. A snapshot of my orginal drawing layout. I did this because I am want to convert a 3-d drawing to a single layer. When I edit the exported drawing I find many entites on top of each other and some lines extend out to left field when I use extend. Is there a way to make this exported drawing user friendly. I did covert all entites to elevaion 0 which helps. Is there a better way to get a 2-d drawing layout form a 3-d drawing for layer conversion. Thank you, Quote
muck Posted August 5, 2009 Author Posted August 5, 2009 So FlatShot is only good in Model Space. What about layout. Does it put everthing on layer 0? Quote
ReMark Posted August 5, 2009 Posted August 5, 2009 Flatshot works in model space. It will create an anonymous block and place it on the current layer using the layer's color and linetype settings. You have the option to override both the color and the linetype for foreground lines and obscured lines. Quote
ReMark Posted August 5, 2009 Posted August 5, 2009 If you EXPLODE the block it will revert to layer 0. The color of the linework may still be overridden. Quote
ReMark Posted August 5, 2009 Posted August 5, 2009 Example using FLATSHOT command. The original solid object is on the left. The block it created is shown in the middle. The layer it was created on has its color set to green. I used the Hidden2 linetype for obscured lines and set it to color red. The object on the right is the exploded version of the block. Foreground line color reverts to white (the default for layer 0). The obscured lines remain red. Quote
muck Posted August 5, 2009 Author Posted August 5, 2009 Most of the drawings that I want 2-versions of are in paper space that has a viewport looking into model space. The 3-d models are in viewports. What I need is a clean 2-drawing of what is shown in paper space. The export to model functions seems like it might be doing that but resulting objects are difficult to edit becuse there are overlapping entities, etc. Maybe a Flashshot to an exported file in model space could help clean complex (odd ) entities up for editing? Thank you, Quote
ReMark Posted August 5, 2009 Posted August 5, 2009 I think the solution offered (Flatshot) is pretty straight-forward. I'm having trouble understanding where you are experiencing a problem. I also don't understand why it is necessary to further edit the geometry of the resultant 2D object(s). Sorry. Quote
ReMark Posted August 5, 2009 Posted August 5, 2009 The Export to file option will result in a DXF file being created. Quote
ReMark Posted August 5, 2009 Posted August 5, 2009 Maybe you should look into the SOLPROF command. The command takes a snapshot of the 3D object through the viewport. It will create a 2D block. Solid lines will appear on a layer with the prefix PV- while hidden lines will be on a layer with the prefix PH-. You can denote the color, linetype, etc. of these lines. Quote
muck Posted August 5, 2009 Author Posted August 5, 2009 The "Export Layout To Model" has worked the best for two drawings. On all my other 3-D exports I get "eKey Not Found". I wonder what is causing that??? These are complex 3-D drawings???? Thank you, Quote
