EngTech Posted August 4, 2009 Posted August 4, 2009 Hi Guys, Just joined this forum as I'm currently learning AutoCAD. I have a text box which I need to display on top of a hatched area. However, I find when I attempt to 'move' the text over the hatched area, it disappears behind the hatch. In otherwords, it isn't visible. Could anyone help with this one? I've attached a file which shows the text 'XX XX 01'. I need to move this unto the blue hatched area. Best regards, Paul Quote
CADMASTER1128 Posted August 4, 2009 Posted August 4, 2009 Welcome to the forum, glad to see you joined. Click on the text or Hatch Pattern and using the drawing order to edit. (Bring Front, Send Back) Quote
CADMASTER1128 Posted August 4, 2009 Posted August 4, 2009 You can also try right clicking on the object: Quote
EngTech Posted August 4, 2009 Author Posted August 4, 2009 Thanks very much. Have it now. Best regards, Paul Quote
Amanda Posted September 21, 2009 Posted September 21, 2009 Hello Sir, I have a problem, when i hatch with the text in the area, i can not remove the text box, though paul in the upstair said move the text the box disppeared, but by my side the box go where the text go, i don't want the box, what should i do ? i tried "sent to back", but it can not help. i know when hatch "ignore" option can hlep, but it will efflence other objects. waiting for your reply! thanks in advance! Amanda Quote
