hello to all
i got this lisp from this forum
it is to copy texts individualy then replace it sequantialy i try to new text to a new layer but in vain any help will be appreciated
thanks
sory for my english
;copy text then replace it sequentialy to new position to predefined layer
(defun C:mmm( / tl e p)
(command"ucs" "world")
(setq clyr(getvar"clayer"))
(setq tl nil)
(while (setq e (car (entsel "\nSelect text :")))
(redraw e 3)
(setq tl (append tl (list e)))
(command "layer" "m" "moved text" "")
(command "layer" "c" "1" "moved text" "")
(while (> (length tl) 0)
(setq p (getpoint "\nNew position:"))
(command "copy" (setq e (car tl)) "" (cdr (assoc 10 (entget e))) p)
(setq e1 (entlast))
(command "chprop" e1 "" "la" moved text "")
(setq tl (cdr tl))
(setvar"clayer"clyr)
Hello motee-z,
This code works for me. The comment line that talks about a "predefined layer" might be confusing. The program copies selected text to the current layer. The program creates a layer "moved text" to hold the text temporarily but restores the original layer at the end. The program is rough, with no error trap or even (princ) at the close, but it seems to work.
Edit : maybe the intention was to leave the selected text on the MOVED TEXT layer. To do that change the line :
to
(command "chprop" e1 "" "la" "moved text" "")
I don't quite understand what you want this LISP to do for you?
An alternative approach to things;
(defun c:cptxt (/ lay ss sel)
 (vl-load-com)
 (setq lay "Moved Text") ;; << New Layer
 (if (not (tblsearch "LAYER" lay))
   (vla-put-color
     (vla-add
       (vla-get-layers
         (vla-get-ActiveDocument
           (vlax-get-acad-object))) lay) 1))
 (if (setq ss (ssget '((0 . "*TEXT"))))
     (vlax-for Obj (setq sel (vla-get-ActiveSelectionSet
                                 (vlax-get-acad-object))))
       (vla-copy Obj) (vla-put-layer Obj lay)
       (command "_.move"
         (vlax-vla-object->ename Obj) ""
           (vlax-get Obj 'InsertionPoint) pause))
     (vla-delete sel)))
 (princ))
thank you calcad thanks to lee mack
the problem is solved
mr lee mack the aim of lisp is to select text one by one and place them in new place in the same order in another layer
Does the above work for you?
Motee-z,
Glad you have something that works, whichever solution you used.
