W3D Posted August 5, 2009 Posted August 5, 2009 I have noticed this problem with AutoCAD Architecture 2009 for quite some time now. Sometimes, if i have duplicated/mirrored many of the same model in a drawing (e.g. chairs), some of the filleted edges tend to revert back to a straight 'un-filleted' edge. At first I thought this might just be a display problem when in wireframe, but it also effects my renders. I have tried with solid history on and off but it doesn't seem to make a difference. What could be the cause of this? Quote
CADMASTER1128 Posted August 5, 2009 Posted August 5, 2009 I don't know what would cause it, but if you type REGEN ands ee of that helps. Quote
JD Mather Posted August 5, 2009 Posted August 5, 2009 I have tried with solid history on and off but it doesn't seem to make a difference. Did you have solidhist (brep) turned off before you started or did you turn it off after problem appeared. I'm not sure if solidhist causes the problem or just supersition on my part, but I haven't seen the problem since I turned it off. When I open the AutoCAD parts with missing features in Inventor the features return. Quote
