How can i take the name of .txt file, in a multiselection?
i have done this:
Dim lngCount As Long ' Open the file dialog
With Application.FileDialog(msoFileDialogOpen)'.AllowMultiSelect = True
   .Show ' Display paths of each file selected
For lngCount = 1 To .SelectedItems.Count 'MsgBox .SelectedItems(lngCount)
Next lngCount
after that, use data extract on .txt, and process the informations, but i need the name of each .txt file
For the name of .txt file, i have to take the files again, with that code:
Dim txtname As String
   txtname = Application.GetOpenFilename("text files (*.txt), *.txt,")
I don't wanna take each .txt file, i want to take only in the first selection, and record the name in a new variable
This is a vba for excel, but is a complement of my lisp...
I will be very grateful with any help!!
What do you mean by first selection? I am assuming that you mean from a drop down box or a similar form object.
If that is the case you will be able to determine the order of the items in the box by iterating through the list. Compare the selected item list against the contents of the form object.
Does this need to be a multi selection if you are only using the first txt file?
