marlon Posted August 6, 2009 Posted August 6, 2009 Under "Dimension Style Manager" (Dimension --> Style....), why is Standard missing? There is only ISO-25. (This is what's causing my problem http://www.cadtutor.net/forum/showthread.php?t=38914) Thanks!! Quote
lpseifert Posted August 6, 2009 Posted August 6, 2009 Maybe because you used acadiso.dwt (or a form of) as your template. You should be able to use Design Center to drag and drop the Standard dimension style from a different dwg/dwt into your dwg. Quote
