NBC Posted May 15, 2008 Posted May 15, 2008 I have just had a new machine given me; and on it has been installed AutoCAD Map 3D 2009. I am having trouble publishing more than one paperspace layout at a time. The publish command looks to be doing everything it used to do, on my old machine. But when I come to view the pdf output, it only ever has the very first layout to be printed. Any idea as to how I can get publish to output more than one layout at a time to a pdf file? I am using exactly the same printer drivers (Adobe PDF) and exactly the same operating system (Windows XP) as on my old machine. Let me know if you need any more information. Please note the following variables: PUBLISHALLSHEETS - set to 1 PUBLISHCOLLATE - set to 1 Quote
Guest Alan Cullen Posted May 15, 2008 Posted May 15, 2008 Blue, I only started using publish a couple of weeks ago. The first thing I found out was that when I sent the publish job to a particular printer, it all just froze. But worked fine on the other printers/plotters. Then I found out it had a lot to do with whether the printers have sufficient internal RAM, and if the spooling was done in the printer, or in the computer. Maybe you should check that out. Edit..... But PUBLISH in Map 3D 2009 does work fine. Quote
NBC Posted May 15, 2008 Author Posted May 15, 2008 I am trying to publish to a PDF file though, so internal Ram, and spooling are non-starters. I have tried to publish to physical printers, and the print doesn't even appear in the print queue; let alone churn out of the printer. this will do my head in, until it is resolved, i know it Quote
NBC Posted May 15, 2008 Author Posted May 15, 2008 I just tried to publish to a dwf file; and that worked great. It just doesn't work for any other printer/plotter Quote
ReMark Posted May 16, 2008 Posted May 16, 2008 Stab-in-the-dark time. Would this be what you're looking for? http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=8057757&linkID=9240617 Quote
NBC Posted May 16, 2008 Author Posted May 16, 2008 Thanks for that, I shall look into it when I have time Thing is though. Printing to multi-page pdf files used to work without using SSM; so was hoping to follow that path. Interesting how that seems to be no longer possible Quote
ReMark Posted May 16, 2008 Posted May 16, 2008 Maybe AutoDe$k justs thrives on making users' lives miserable. Here's a quote from an explanation on the topic "Project plotted to PDF file only creates one PDF file of last DWG file". It appears at the end of the explanation on how to solve the problem. "A PDF file should be created for each of the DWG files. However, a PDF file will not be created for all of the DWG files." Huh? And they call this help? Quote
NBC Posted May 16, 2008 Author Posted May 16, 2008 It used to work; why 'fix' what isn't broken ? Is that the American way ? (Apologies to all the decent Americans out there) Quote
ReMark Posted May 16, 2008 Posted May 16, 2008 I'm pretty indecent myself so no apology required. Why fix what isn't broken? Because they can. Did you know that from time to time AutoDe$k will put in a command, then remove it and then put it back in? Or it will change the location of the command? How about those "undocumented" commands? Why include them? Is it a test for the reviewers? Quote
nailer341 Posted September 10, 2008 Posted September 10, 2008 Has anyone found a solution for this? i was hoping the service pack 1 would have addressed this issue, but thus far it hasn't fixed it for me. Quote
Sidd Posted September 22, 2008 Posted September 22, 2008 It sucks but it works. I have been publishing to DWF and then, from Design Review I print to PDF. I have noticed that AutoCAD is forcing you to work with .pc3 files. system printers are not getting the deserved attention in there fixes and corrections. also worth to check this out... cant post a link yet.. try to add http:// in front of.. usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=8057757&linkID=9240617 didn't work for me though. Hope that works.. Quote
spittle Posted September 29, 2008 Posted September 29, 2008 I'm having a similar problem. I'm using AutoCAD Civil 3D 2009 as AutoCAD. I can't publish more than one page at a time on my PC, I have 8 2.66GHz Xeon cores and 8GB memory with 64bit XP. Just tried with 2008 on a colleagues PC - 2xPentium D 3GHz, 2GB RAM XP 32 and it works fine. All 64 drawings are now printing. any ideas? Quote
