Hello everyone
I have a problem with matching properties of hatches.
I created one hatch in DWG1 and copied it to DWG2. Both DWGs are created by me, in same autocad, saved in same format, both have same LTSCALE…
But, when i try to match properties of copied hatch to a newly created one in DWG2, something strange is happening.
They don’t look the same!
Properties say they have the same scale, but new one is much "smaller".
Here is a video of what's going on:
http://www.box.net/shared/80upmljyi6
Any ideas? Google failed me…
Thanks in advance!
if you have adobe pro, try to plot in pdf, just to see the result.
I plot to pdf with PDFCreator. And plotted is just the same as in Autocad. WYSIWYG.
You might want to try changing the hatch origin. Go into the hatch editor and under "Hatch Origin" choose "click to set new origin", then pick a point inside your hatch boundary and see if that helps.
If the size ratio is about 25 then you are seeing the effect of the MEASUREMENT sysvar. Check its value.
That's it! Thanks hugha!
