PDS Posted May 15, 2008 Posted May 15, 2008 Hi, well, the topic title says it all. Right now, when i click one object and then another, the first object becomes deselected. Holding shift is the only way for me to select multiple lines right now (other than dragging of course) but that's not what I'm used to and it annoys me a lot. At first everything is fine but then after a while it does this without me changing any options at all. Does anyone know how to solve this? Thanks in advance! Quote
Dipali Posted May 15, 2008 Posted May 15, 2008 Check Your 'pickfirst' Variable Setting oops sorry it is 'PICKADD' Quote
CADTutor Posted May 15, 2008 Posted May 15, 2008 Welcome to the forums. I think you need this FAQ article. Quote
PDS Posted May 15, 2008 Author Posted May 15, 2008 Thanks for the fast answer! I've set pickfirst to both 0 and 1 with no result. Quote
PDS Posted May 15, 2008 Author Posted May 15, 2008 Welcome to the forums. I think you need this FAQ article. Thanks a million. That did the trick. Thanks again. Quote
Guest Alan Cullen Posted May 15, 2008 Posted May 15, 2008 Ahhhh, ya gotta love it. The value of the FAQ. Welcome aboard PDS. Quote
PDS Posted May 15, 2008 Author Posted May 15, 2008 Ahhhh, ya gotta love it. The value of the FAQ. Welcome aboard PDS. Yeah I had been looking through that but I wasn't sure where to look Still, I wonder why this thing happens to me at random times without me doing anything out of the order. I just had to use the pickadd option again...? Quote
Tiger Posted May 15, 2008 Posted May 15, 2008 are you using any form of customization, i.e. Lisps, Vba etc? These can reset variables without the user knowing... Quote
LCE Posted May 15, 2008 Posted May 15, 2008 are you using any form of customization, i.e. Lisps, Vba etc? These can reset variables without the user knowing... Bare in mind that users can also have customisation files running without knowing. I centralized the ACADDOC.LSP a few months ago, and just got asked yesterday if I had changed something... Quote
MACdwg Posted November 18, 2011 Posted November 18, 2011 Hello, I have this exact same problem so I read thru the posts and when I tried to click the FAQ link the Admin. posted it gives me a PAGE NOT FOUND : ERROR. Any help on fixing the issue would be AWESOME. Quote
Dana W Posted November 18, 2011 Posted November 18, 2011 Read below list of similar threads "Select multiple Objects." Quote
MACdwg Posted November 21, 2011 Posted November 21, 2011 So no GOOD reply's .. I will figure this out!!.. It started last week going along fine I could select multiple objects without haveing to hold down SHIFT, then I close CAD now I can only select 1 object at a time or press SHIFT to select multiple objects. Thanks. Quote
RocketSurgeon Posted November 21, 2011 Posted November 21, 2011 So no GOOD reply's .. I will figure this out!!.. It started last week going along fine I could select multiple objects without haveing to hold down SHIFT, then I close CAD now I can only select 1 object at a time or press SHIFT to select multiple objects. Thanks. Type "options" in the command line. choose the "selection" tab. Under Selection Modes... Is "Use Shift to add to selection" checked? Quote
SLW210 Posted November 21, 2011 Posted November 21, 2011 Type "options" in the command line. choose the "selection" tab. Under Selection Modes... Is "Use Shift to add to selection" checked? That is the same as the _PICKADD system variable. PICKADDControls whether subsequent selections replace the current selection set or add to it. 0 Turns off PICKADD. The objects and subobjects most recently selected become the selection set. Previously selected objects and subobjects are removed from the selection set. Add more objects or subobjects to the selection set by pressing SHIFT while selecting. 1 Turns on PICKADD. Each object and subobject selected, either individually or by windowing, is added to the current selection set. To remove objects or subobjects from the set, press SHIFT while selecting. 2 Turns on PICKADD. Each object and subobject selected, either individually or by windowing, is added to the current selection set. To remove objects or subobjects from the set, press SHIFT while selecting. Keeps objects selected after the SELECT command ends. Quote
Dana W Posted November 21, 2011 Posted November 21, 2011 So no GOOD reply's .. I will figure this out!!.. It started last week going along fine I could select multiple objects without haveing to hold down SHIFT, then I close CAD now I can only select 1 object at a time or press SHIFT to select multiple objects. Thanks. That depends on your frame of reference now doesn't it. Good luck with your issue. Quote
MACdwg Posted November 29, 2011 Posted November 29, 2011 That depends on your frame of reference now doesn't it. Good luck with your issue. Right you are!.. However I figured out my problem. I appreciate all the help thanks!. Quote
