A393 Posted August 7, 2009 Posted August 7, 2009 Would welcome your thoughts. Is there a way to select multiple I.D. points, i.e. in this case coordinates for setting out piles and generate a table of results. I'm using LT 2009. At present I type mutiple, select I.D. then pick about 10 to 20 locations before copy & pasting from the command line into a block of mtext which I then have to edit to delete the 'Z' coordinate and other bits of unwanted text etc. Then I select another 10 to 20 and so on & so on. Thank you in advance Quote
eldon Posted August 7, 2009 Posted August 7, 2009 The way you are doing it, is probably as good as you can do with AutoCAD LT. LT is the problem If you had the full version of AutoCAD, there are lisps routines that will help. Quote
Lee Mac Posted August 9, 2009 Posted August 9, 2009 As Eldon says, LT has so many restrictions when it comes to customisation. If you have any access to the full version at all, then these may help: http://www.cadtutor.net/forum/showthread.php?t=36808 http://www.cadtutor.net/forum/showthread.php?t=36328 http://www.cadtutor.net/forum/showthread.php?t=19666&page=4 http://www.cadtutor.net/forum/showthread.php?t=38525 http://www.cadtutor.net/forum/showthread.php?t=36668 http://www.cadtutor.net/forum/showthread.php?t=37762 Lee Quote
A393 Posted August 10, 2009 Author Posted August 10, 2009 Cheers Guys, You know your stuff, we should be getting hold of a full version soon for our small office exactly for this type of thing....ive noted the links you have sent through and will have a play around when we get an upgrade. thank you. Quote
Lee Mac Posted August 10, 2009 Posted August 10, 2009 Not a problem, happy to help mate :wink: Lee Quote
Tankman Posted August 11, 2009 Posted August 11, 2009 LT versions, many "things" not available. Let us know after you upgrade to full, I'm sure Lee Mac is steering, as always! Quote
