Forgive me - I am a complete lisp noob...
I have tried to set CANNOSCALE with lisp but I keep getting errors.
I have tried using
(command "cannoscale" "1\" = 25'")
and
(setvar "cannoscale" "1\" = 25'")
but neither seem to work. The scale is in the dwg already.
Help please?
  • Replies 21
  • chulse
    8
  • The Buzzard
    6
  • Lee Mac
    4
  • alanjt
    3
Try
(setvar "cannoscale" "1 = 300")
Nope - still says it can't do it.
Thanks though
Is it available in the Scale List?
yes
it's in the list as 1" = 25'
I went directly to setvar and I guess it assumes it a string.
Command: setvar
Enter variable name or [?] :
Enter new value for CANNOSCALE, or . for none :
Had no problem with this, But it cannot be written the way you have it. Not sure.
Command: setvar
I just tried this:
Command:
SETVAR Enter variable name or [?] :
Command: (setvar "cannoscale" "1\" = 25'")
"1\" = 25'"
Did not get an Invalid responce.
1" = 25'
The strange thing is, I could not delete it from the list.
I do not understand why. The delete button will not activate for this scale only.
1" = 25'
probably have, either an object or viewport, associated with the scale.
you should be able to set it fine (with setvar):
Command: (setvar "cannoscale" "1\" = 20'")
"1\" = 20'"
I am in model space in a new drawing with nothing in the drawing editor. I created the scale new. It will not delete. There are no viewports.
how bizarre. i just created a custom scale, closed, set it as current, then set a different scale as current and was able to delete it just fine.
hmm
I just tried this:
Command:
"1\" = 25'"
Was this direct on the command line or embedded in a lisp?
It works fine for me on the command line, but not in the lisp...
Could it be something else with the lisp?
Anything that works on the command line would work in a LISP, so one would have to assume that it is something other than this that is causing your LISP to fail.
Lee
This is how I have it in context. Any thoughts?
(defun c:svp ( / ss)
(command "_mspace"_)
(setq ss (ssget))
(command "_ucs" "_object" ss)
(command "_plan" "_current")
(command "_zoom" "c" "0,0" "180")
(command "regenall")
);;defun
Try this Chulse:
(defun c:svp  (/ ss)
 (if (zerop (getvar "TILEMODE"))
   (command "_.mspace"))
 (if (setq ss (ssget))
     (command "_.ucs" "_object" ss)
     (command "_.plan" "_current")
     (command "_.zoom" "c" "0,0" "180")
     (setvar "CANNOSCALE" "1\" = 25'")
     (command "_.regenall")))
 (princ))
You had an error in your "mspace" command.
Also, you cannot invoke the mspace command whilst in ModelSpace.
And, you should allow for an empty selectionset.
Lee
Thanks for the suggestions. The rest of the code works great, but this still does not work:
it seems like it is just ignoring it now - no error on the command line...
Try this Chulse:
(defun c:svp  (/ ss)
 (princ))
Lee
Lee,
I meant to ask - why the "." before the command name? What does it mean?
Thanks for all your help.
I still can't get the cannoscale bit to work...even when I try it alone...
Regarding prefixes for commands:
" _" allows for other language versions.
" . " uses the original command if it has been redefined by the user.
Awesome, thanks
I might just learn lisp yet... with your help!
