PanHasan Posted August 8, 2009 Posted August 8, 2009 Hi i have a simple problem i think but im new at vba so im asking So i've got a line in drawing and i pick one point i would like to draw a horizontal line from my point to the line in the drawing but i have no idea how to do it hope somebody could help Quote
PanHasan Posted August 8, 2009 Author Posted August 8, 2009 I figure out that I could use a ray to draw a line betwen point and a line but how could i find the point where it cros the other line ? in lisp where something like inters but in vb i dont know how Quote
SEANT Posted August 8, 2009 Posted August 8, 2009 Before potentially giving inappropriate advise: Which flavor of vb are you interested in, VBA/VB6 or VB.NET? I suppose a example file (preferably in 2007 format) illustrating a before and after would also be helpful. Quote
PanHasan Posted August 8, 2009 Author Posted August 8, 2009 im trying to write in vb net (sorry for that vba) i have a line in drawing and i know how to draw a ray using macro but i dont know how could i find a point where it intersects if they intersect thx for reply Quote
SEANT Posted August 9, 2009 Posted August 9, 2009 Both a Line and Ray derive from the Database CURVE class which, in turn, derives from database ENTITY. As entities, both can employ the Entity.IntersectWith method. <CommandMethod("LRInt")> _ Public Sub LineRayIntersect() Dim db As Database = HostApplicationServices.WorkingDatabase Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor db.Pdmode = 66 'just to make the points more visible Dim peo As PromptEntityOptions = New PromptEntityOptions("Select a Line: ") peo.SetRejectMessage("Select only a line!") peo.AddAllowedClass(GetType(Line), False) Dim tr As Transaction = db.TransactionManager.StartTransaction() Using tr Try Dim per As PromptEntityResult = ed.GetEntity(peo) If per.Status <> PromptStatus.OK Then Exit Sub Dim ln As Line = tr.GetObject(per.ObjectId, OpenMode.ForRead) peo.SetRejectMessage("Select only a Ray!") peo.Message = "Select a Ray: " peo.RemoveAllowedClass(GetType(Line)) peo.AddAllowedClass(GetType(Ray), False) per = ed.GetEntity(peo) If per.Status <> PromptStatus.OK Then Exit Sub Dim ry As Ray = tr.GetObject(per.ObjectId, OpenMode.ForRead) Dim ptc As Point3dCollection = New Point3dCollection() Dim intthis As Integer Dim intThat As Integer ln.IntersectWith(ry, Intersect.OnBothOperands, ln.GetPlane(), ptc, intthis, intThat) If ptc.Count < 1 Then Exit Sub Dim ptAtInters As DBPoint = New DBPoint(ptc(0)) Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) btr.AppendEntity(ptAtInters) tr.AddNewlyCreatedDBObject(ptAtInters, True) tr.Commit() Catch ed.WriteMessage("Error during execution!") tr.Abort() End Try End Using End Sub Quote
PanHasan Posted August 9, 2009 Author Posted August 9, 2009 Thanks thats a great help from you but i wonder if there is a posibility to find that point by the ray itself without selecting the line by the user Quote
SEANT Posted August 9, 2009 Posted August 9, 2009 It is possible but the routine would have to be set up to iterate through all the curves in the active space that meet the desired criteria. See: Editor.SelectAll Method (SelectionFilter) Then the same process shown in my previous post would be used on all the filtered curves using the Ray as the base. i.e., ry.IntersectWith(curve, Intersect.OnBothOperands, ry.GetPlane(), ptc, intThis, intThat). If you have problems setting that up, post your code and we’ll do our best to offer suggestions. Quote
PanHasan Posted August 9, 2009 Author Posted August 9, 2009 Ok thanks for all help but i'll try to do it by myself if i'll fail then i'll back ;] Quote
PanHasan Posted August 9, 2009 Author Posted August 9, 2009 Hi once again i made something like that the ray finds the first line(point on a line) on its way any suggestion how could i get the id of that line thats what i wrote <CommandMethod("pts")> _ Public Sub pts() Dim lineCmd As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim acadBaza As Database = lineCmd.Document.Database Dim trans As Transaction = acadBaza.TransactionManager.StartTransaction Dim opPoint As PromptPointOptions = New PromptPointOptions("Kliknij srodek pomieszczenia :") Dim rePoint As PromptPointResult = lineCmd.GetPoint(opPoint) ' confstruction of filter Dim typeValue() As TypedValue = {New TypedValue(0, "line")} Dim selFilter As SelectionFilter = New SelectionFilter(typeValue) Dim selectResult As PromptSelectionResult = lineCmd.SelectAll(selFilter) If rePoint.Status = PromptStatus.OK Then Dim rePoint2 As Point3d = New Point3d(rePoint.Value.X + 10, rePoint.Value.Y, 0) Dim prosta As Ray = New Ray() prosta.BasePoint = rePoint.Value prosta.SecondPoint = rePoint2 Try Dim btr As BlockTableRecord = trans.GetObject(acadBaza.CurrentSpaceId, OpenMode.ForWrite) btr.AppendEntity(prosta) trans.AddNewlyCreatedDBObject(prosta, True) If selectResult.Status = PromptStatus.OK Then Dim ss As SelectionSet = selectResult.Value Dim idTab() As ObjectId = ss.GetObjectIds() Dim ra As Ray = CType(trans.GetObject(prosta.Id, OpenMode.ForRead), Ray) Dim ptc As Point3dCollection = New Point3dCollection() Dim intthis As Integer Dim intThat As Integer Dim objId As ObjectId For Each objId In idTab Dim ln As Line = CType(trans.GetObject(objId, OpenMode.ForRead), Line) ln.IntersectWith(ra, Intersect.OnBothOperands, ln.GetPlane(), ptc, intthis, intThat) Next Dim pts As Point3d Dim tmpPt As Point3d tmpPt = ptc.Item(0) Dim i As Integer If ptc.Count > 1 Then For i = 0 To ptc.Count - 1 pts = ptc(i) If pts.X < tmpPt.X Then tmpPt = pts End If Next End If lineCmd.WriteMessage(tmpPt.ToString) End If trans.Commit() Catch ex As Exception lineCmd.WriteMessage("Wywalilo sie jakis wyjatek" + ex.Message) Finally trans.Dispose() End Try End If End Sub It would be nice if somebody could correct me if i'm wrong in some ways Quote
SEANT Posted August 9, 2009 Posted August 9, 2009 Nice code. Here is one possible way of retrieving the appropriate line. Include: Imports System.Collections.Generic <CommandMethod("pts")> _ Public Sub pts() Dim lineCmd As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim acadBaza As Database = lineCmd.Document.Database Dim trans As Transaction = acadBaza.TransactionManager.StartTransaction Dim opPoint As PromptPointOptions = New PromptPointOptions("Kliknij srodek pomieszczenia :") Dim rePoint As PromptPointResult = lineCmd.GetPoint(opPoint) Dim crvDict As Dictionary(Of Double, Line) = New Dictionary(Of Double, Line)() ' confstruction of filter Dim typeValue() As TypedValue = {New TypedValue(0, "line")} Dim selFilter As SelectionFilter = New SelectionFilter(typeValue) Dim selectResult As PromptSelectionResult = lineCmd.SelectAll(selFilter) If rePoint.Status = PromptStatus.OK Then Dim rePoint2 As Point3d = New Point3d(rePoint.Value.X + 10, rePoint.Value.Y, 0) Dim prosta As Ray = New Ray() Dim tmpPt As Point3d prosta.BasePoint = rePoint.Value prosta.SecondPoint = rePoint2 Try Dim btr As BlockTableRecord = trans.GetObject(acadBaza.CurrentSpaceId, OpenMode.ForWrite) btr.AppendEntity(prosta) trans.AddNewlyCreatedDBObject(prosta, True) If selectResult.Status = PromptStatus.OK Then Dim ss As SelectionSet = selectResult.Value Dim idTab() As ObjectId = ss.GetObjectIds() Dim ra As Ray = CType(trans.GetObject(prosta.Id, OpenMode.ForRead), Ray) Dim ptc As Point3dCollection = New Point3dCollection() Dim intthis As Integer Dim intThat As Integer Dim objId As ObjectId Dim x As Double For Each objId In idTab Dim tempptc As Point3dCollection = New Point3dCollection() Dim ln As Line = CType(trans.GetObject(objId, OpenMode.ForRead), Line) ln.IntersectWith(ra, Intersect.OnBothOperands, ln.GetPlane(), tempptc, intthis, intThat) If tempptc.Count > 0 Then For Each pt As Point3d In tempptc x = Math.Round(pt.X, 6) crvDict.Add(x, ln) 'add line to dictionary with X coordinate as Key ptc.Add(pt) Next End If Next trans.Commit() If crvDict.Count > 0 Then Dim pts As Point3d tmpPt = ptc.Item(0) Dim i As Integer If ptc.Count > 1 Then For i = 0 To ptc.Count - 1 pts = ptc(i) If pts.X < tmpPt.X Then tmpPt = pts End If Next End If lineCmd.WriteMessage(tmpPt.ToString) crvDict(Math.Round(tmpPt.X, 6)).Highlight() 'Retrieve line based on X coordinate Key equal to tmpPt.X lineCmd.WriteMessage(" ObjectId: " & crvDict(Math.Round(tmpPt.X, 6)).ObjectId.ToString()) Else lineCmd.WriteMessage("No intersections") End If End If Catch ex As Exception lineCmd.WriteMessage("Wywalilo sie jakis wyjatek" + ex.Message) Finally trans.Dispose() End Try End If End Sub Quote
PanHasan Posted August 9, 2009 Author Posted August 9, 2009 Thank you SEANT you are a great help i think that this thread is end i've get what i need Quote
