papagyi Posted May 16, 2008 Posted May 16, 2008 Now i share from other for undocument system variables for Acad2009. Here's a list of new system variables for 2009. These are the variables that are displayed by the SETVAR command. The variables in the first list can be found in Help. If you know what the undocumented variables do please post back here. ACTPATH ACTRECORDERSTATE ACTRECPATH ACTUI CAPTURETHUMBNAILS DGNIMPORTMAX DGNMAPPINGPATH LAYEREVALCTL MENUBAR MLEADERSCALE MTEXTTOOLBAR NAVSWHEELMODE NAVSWHEELOPACITYBIG NAVSWHEELOPACITYMINI NAVSWHEELSIZEBIG NAVSWHEELSIZEMINI NAVVCUBEDISPLAY NAVVCUBELOCATION NAVVCUBEOPACITY NAVVCUBEORIENT NAVVCUBESIZE PREVIEWTYPE PUBLISHHATCH QPLOCATION QPMODE QVDRAWINGPIN QVLAYOUTPIN ROLLOVERTIPS SHOWMOTIONPIN STATUSBAR Undocumented CBARDISPLAYMODE CDYNDISPLAYMODE CNAMEFORMAT CONSTRAINTRELAX CONSTRAINTSOLVEMODE HIDEXREFSCALES LAYERDLGMODE RENDERQUALITY SKYSTATUS ---------------------------- HIDEXREFSCALES Hides xref scales in the annotation, plot and viewport scale list. 0 xref scales are not hidden 1 xref scales are hidden LAYERDLGMODE Controls the layer dialog display type. 0 the layer dialog is displayed in the legacy dialog 1 the layer dialog is displayed as a modeless (correct term?) dialog Quote
ReMark Posted January 7, 2009 Posted January 7, 2009 MTEXTTOOLBAR Default setting = 2. 0 = MText toolbar never displays. 1 = MText toolbar displayed upon selection of an MText object. 2 = MText toolbar does not display when the Ribbon (version 2009) is on. As regards setting of 1. Undocumented: The MText toolbar will also display when Multiline Text is selected from the Ribbon and the text editor window is defined. Quote
