PellaCAD Posted August 12, 2009 Posted August 12, 2009 I've got an interesting project...(this is VB.NET)... I need to move through each viewport on each layout tab in a drawing, doing a zoom-extents in each one. I know it will entail a couple of loops, but I keep getting hung up on moving through all the viewports. Here's some code... **************************************** For Each Item In Me.lbSelectAnAutoCADLayout.SelectedItems objAcad.ActiveDocument.ActiveLayout = objAcad.ActiveDocument.Layouts.Item(Item) OriginalSpace = objAcad.ActiveDocument.ActiveSpace objAcad.ActiveDocument.SendCommand("pspace" & vbCr) objAcad.ActiveDocument.SendCommand("zoom extents ") objAcad.ActiveDocument.SendCommand("mspace" & vbCr) objAcad.ActiveDocument.SendCommand("zoom extents ") objAcad.ActiveDocument.ActiveSpace = OriginalSpace Next **************************************** Eventually I'll need to find and activate a specific viewport on a layout (based on viewport width). But for now, just moving through each viewport on each tab in a drawing will be sufficient. Thanks in advance for your expert help! Go CADTutor! Quote
VVA Posted August 12, 2009 Posted August 12, 2009 Function in lisp (defun vpactivate ( width / ss avp) ;;; width [real] - viewport width for activate ;;; Usage ;;; (VPACTIVATE 199) ;;; Activate VIEWPORT with width 199 ;;; Return number (for CVPORT command) VIEWPORT in layout or nil (vl-load-com) (if (setq SS (ssget "_X" (list '(0 . "VIEWPORT") '(-4 . "/=") '(68 . 1)(cons 410 (getvar "ctab"))))) (progn (foreach vp (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex ss))) (if (equal (cdr(assoc 40 ;_Width code. Height code - 41 (entget vp) ) ) width 1e-6 ) (progn (setq avp (cdr(assoc 68 (entget vp)))) (command "_MSPACE" "_CVPORT" avp "_PSPACE") ) ) ) ) ) avp ) Load this functions and use objAcad.ActiveDocument.SendCommand("(VPACTIVATE 199)" & vbCr) 199 - width specific viewport Quote
PellaCAD Posted August 12, 2009 Author Posted August 12, 2009 Thanks VVA!! Well done! (I think I can use this as a temporary solution.) I still need a VB dot NET solution... (Thanks again VVA...your LISP solution is clean and elegant...and it works!) Quote
