spursnutter Posted August 12, 2009 Posted August 12, 2009 Is there a way to set the interfere tool to zoom in closer to interfered objects? Quote
ReMark Posted August 12, 2009 Posted August 12, 2009 How close is close? I just ran a test of the INTERFERE command in a drawing containing 191 3D solids. When prompted I windowed all the objects. It found four objects with interferences and zoomed to that area of the drawing. At this point the Interference Checking dialog window appeared. I clicked on the Next button and it zoomed to a single object (out of the four) filling my entire screen. I noticed that the box in front of Zoom to pair was checked off. This doesn't happen for you? Quote
spursnutter Posted August 12, 2009 Author Posted August 12, 2009 I think they may be the problem. Zoom to pair was checked. I will see when I am in work tomorrow to see if that is the problem. Quote
ReMark Posted August 12, 2009 Posted August 12, 2009 Zoom to pair was or was not checked? Mine definitely was checked. I could also cycle through the 4 objects that had interferences with each set being brought up, full screen, for viewing. Quote
