Kremer Posted August 12, 2009 Posted August 12, 2009 I'm using a .ctb which displays all colors as black, except colors above #150. It doesn't affect lineweights, yet for some reason my layers with .3 and .5 lineweights still show up as the default (or what seems .0) in paper space. In model space it looks fine. Quote
wandyhee Posted August 13, 2009 Posted August 13, 2009 might be because the line weight you set in .ctb is all same.. that will cause the line weight you set on layers useless. the best way to set the lineweight is by colors in .ctb, for example color1 (red)= 0.2, color2(yellow)=0.15, color3(green)=0.35 and so on.. leave all the lineweight in layers as default. Quote
