Macro with a mind of its own?
Hey,
I've put together a macro that will assist in tying up the loose ends in a drawing before issuing it. Rather than explaining it then reiterating, here is the code I have constructed so far;
^C^C-layer;s;0;;tilemode;0;zoom;all;-purge;all;;no;-scalelistedit;reset;y;exit;zoom;all;_qsave;close;
It seems to do the job, although there is one flaw. When I initiate this macro, it runs through all the steps and closes the drawing file. When the drawing file is opened again, the title block in paper space has disappeared! Only the lines go, not the text, so I am left with a view port, paper space objects and a title block that does not show anything but the attributes within it. There's nothing in the code that instructs to alter the drawings layout, so why is this happening? Help!
Works Fine For Me
What Layer Is Your Tb On
Are The Lines Gone Or Just Turned Off?
My title block is on a layer called "CSP_NEG" with the text inside on a layer "CSP_TITLE TEXT". Through further interrogation it i have found that the block that holds all the linework nested within the title block itself gets purged despite its existence within the drawing!
