Sticks Posted August 13, 2009 Posted August 13, 2009 All, I just started to work with the part builder in Civil3d 2008. I was able to create a structure and it seems to look proper with the the dim's and the constraints etc. But when I go to validate the part I get an error. The error reads as follows: Error: part type parameter not validated Validation summery--level 1 errors found. Is there a way to find were the error or what the error is? Thanks Sticks Quote
JerryG Posted August 21, 2009 Posted August 21, 2009 Pipe parts created with Part Builder must have a width, a height, and a centerline. Therefore, any pipe shapes that do not meet this criteria will not work. Also the section profiles of a pipe must have an enclosed loop. Could it be possible your loop does not close?? Quote
