  • 2 weeks later...
  • Replies 25
  • Lee Mac
    11
  • Tiger
    10
  • eldon
    2
  • NBC
    1
soo....how hard would it be to get the last lisp in here to pick up the Z-coordinate as well? :oops:
I brought up an old thread to save me the hassle of copying the Lisp ofc :wink:
Perhaps:
(defun c:cr (/ *error* doc lFac tSze tLay tSty vl ov pt t1 t2 t3)
 (vl-load-com)
 (setq doc (vla-get-ActiveDocument
             (vlax-get-acad-object)))
 (defun *error* (msg)
   (if doc (vla-EndUndoMark doc))
   (if ov (mapcar 'setvar vl ov))
   (if (not
         (wcmatch
           (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
     (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (setq
   lFac 1.5    ;; <<-- Line Spacing Factor
   tSze 5.0    ;; <<-- TextSize (nil to use TEXTSIZE sys var)
   tLay "TEXT" ;; <<-- Text Layer (nil to use CLAYER sys var)
   tSty nil    ;; <<-- Text Style (nil to use TEXTSTYLE sys var)
 (setq vl '("CMDECHO" "OSMODE")
       ov (mapcar 'getvar vl))
 (setvar "CMDECHO" 0)
 ;;<<--  Error Checking  -->>
 (cond ((not (and (numberp lFac) (< 0 lFac)))
        (princ "\n** Line Spacing not Valid **"))
       ((and tLay (not (eq 'STR (type tLay))))
        (princ "\n** Layer not a String **"))
       (t
        (or tSze (setq tSze (getvar "TEXTSIZE")))
        (or tLay (setq tLay (getvar "CLAYER")))
        (or tSty (setq tSty (getvar "TEXTSTYLE")))
        (and tLay (not (tblsearch "LAYER" tLay))
             (vla-add
               (vla-get-layers doc) tLay))
        ;; <<-- Business End  -->>
        (while (setq pt (getpoint "\n Välj Punkt - <RETURN> för att avsluta :"))
          (vla-StartUndoMark doc)
          (setvar "OSMODE" 0)
          (setq pt (trans pt 1 0))
          (command "_.point" pt)   ;; << Comment this if unnecessary
          (setq t1
            (Make_Text pt
              (strcat "X: " (rtos (/ (car pt) 1000.)))
              0.  ;; Text is at 0 deg.
              tSze tLay tSty))
          (setq t2
            (Make_Text (polar pt (/ (* 3 pi) 2.) (* lFac tSze))
              (strcat "Y: " (rtos (/ (cadr pt) 1000.)))
              0.
              tSze tLay tSty))
          (setq t3
            (Make_Text (polar pt (/ (* 3 pi) 2.) (* lFac 2 tSze))
              (strcat "Z: " (rtos (/ (caddr pt) 1000.)))
              0.
              tSze tLay tSty))
          (setvar "OSMODE" (cadr ov))
          (command "_.move" t1 t2 t3 "" pt pause)
 (princ))
;; <<--  Sub-Function  -->>
(defun Make_Text  (pt val rot sZe lay sty)
 (entmakex
   (list
     (cons 0 "TEXT")
     (cons 8  lay)
     (cons 10 pt)
     (cons 40 sZe)
     (cons 1  val)
     (cons 50 rot)
     (cons 7  sty)
     (cons 71 0)
     (cons 72 1)  ;; 0 = Left, 1 = Center, 2 = Right
     (cons 73 1)  ;; 0 = Base, 1 = Bottom, 2 = Middle, 3 = Top
     (cons 11 pt))))
  • 1 month later...
sorry to jump on this, usefull post, its what I was after.
I just used this on and works fine, how difficult would it be to have a arrow from the point to the location of the xy coordinates iplace on the drawing. It's just that some point are close together and I could get them mixed.
And also for it to display the xy values to 3 decimal places.
This is the one I'm using:
(defun c:cr (/ *error* doc lFac tSze tLay tSty vl ov pt t1 t2)
(vl-load-com)
(if (not
(wcmatch
(princ))
(setq
lFac 1.5 ;;
tSze 5.0 ;;
tLay "TEXT" ;;
tSty nil ;;
(t
(vla-add
(while (setq pt (getpoint "\n Välj Punkt - för att avsluta :"))
(setvar "OSMODE" 0)
(setq t1
(Make_Text pt
tSze tLay tSty))
(setq t2
0.
tSze tLay tSty))
(command "_.move" t1 t2 "" pt pause)
(princ))
(entmakex
(list
(cons 0 "TEXT")
(cons 8 lay)
(cons 10 pt)
(cons 40 sZe)
(cons 1 val)
(cons 50 rot)
(cons 7 sty)
(cons 71 0)
(cons 11 pt))))
  • 4 years later...
I use this simple one, it makes leader but dosen't put X and Y textes
(vl-load-com)
(defun C:CV ; = PolyLine Vertex Coordinates Labeler
(/ pl par ver txt)
(setq
pl (car (entsel "\nSelect Polyline to label its vertices: "))
par -1
); setq
(repeat (cdr (assoc 90 (entget pl))); number of vertices
(setq
ver (vlax-curve-getPointAtParam pl (setq par (1+ par)))
txt (strcat (rtos (/(cadr ver) 1) 2 3) "\\P" (rtos (car ver) 2 3))
); setq
(command "_.leader" "_none" ver pause "" txt "")
); repeat
); defun
if anyone could help edit to add prefix exp. X= Y= and choose text size
thankx for everyone
