idavid Posted August 14, 2009 Posted August 14, 2009 Hi, when I plot to JPEG format the lines look really faint and I can hardly make out the drawing. When plotting to PDF format the lines are much stronger. I need to load this drawing into a particular program which doesn't accept PDF's. The drawing will be viewed on a screen in a courtroom so it needs to be bright and clear. How can I make JPEG clearer? Any help will be much appreciated. Quote
Danse_Macabre Posted August 14, 2009 Posted August 14, 2009 What I have done before is plot to PDF, and then from PDF I plot to tiff. This always seems to work well for me. Maybe give that a try. Quote
chelsea1307 Posted August 14, 2009 Posted August 14, 2009 if you have full acrobat you can change a pdf to jpeg by doing a saveas Quote
rkent Posted August 14, 2009 Posted August 14, 2009 I bump up the resolution to get the desired result. You might have to create a custom page size with larger numbers. Quote
