getting degree symbol to show when dimming angles
Hey there, I am having a spot if trouble in that when I manually enter the angle while dimming I lose the degree symbol, is there some method to get it back?
You are Text Overriding the dimension?
If so, then use ALT + 0176 to get the degree symbol
KC
KC
Ahh, keyboard shortcuts, duh!
Thank you!
does %%c work in dimensions
I think your finger slipped and you meant %%d for degrees, and it works for me :D
%%c is the diameter symbol.
And yes the %%'s work in dimensions, either as a text override (in conjunction with if you want to keep the dimension value if you stretch it) or in the dimension prefix or suffix boxes.
no, not a slipping finger - pure incompetance.
Alt 0216 works for Ø if you need diameter.
Let's go old school... %%127 = degree symbol
