MEP duct label precision (decimal points)
Hi
I'm labelling some ductwork in AutoCAD MEP and the software is currently set to show 1 decimal place, showing 600.0 x 400.0. Where is the setting to change the decimal point precision to 0, to show 600 x 400 etc? as you do with dimension styles in 2D?
I am using the AecbLabelCurveAdd command form the HVAC pallette.
Can anyone please help?
Thanks
type UNITS and change the Precision from 0.0 to 0. That should do the trick. :)
  • 1 month later...
You are requesting for help that is same problem with me.
  • 5 years later...
For what it is worth, this solution no longer applies to AutoCAD MEP 2015. I was able to change the text style using the "Label Style - Standard" in the Style Manager.
