Hi, all.
I'm trying to insert multileader with a block content into the drawing. For tags I need circle block, so I set up everything in multileader style box. But when i draw it on the screen, the circle with a tag doesn't come up, though the programme asks to enter the tag number. I guess that it might be related with the scale, but i can't find where I can change the scale for the circle block.
Thanks
Check the actual size of the block in the block editor - resize if needed.
Also, see if it is annotative.
Check the base point also...
Thanks, that helped. I opened the block editor and resized it.
