Xref PDF Image!
I have a small problem on xreffing Image. Nomally, I usually save as PDF image in to .TIFT Image, and then I xref that TIFT Image to Cad. That work will made my drawing become greater size and my computer will work slowly. I don't know there is a way which xref PDF Image directly on Autocad 2008. Please show me any solution you know
Thanks in advance!
to reduce the size, convert pdf image to dwf by using dwf writer as a printer. & than insert/xref/underlay dwf in dwg.
That is also a good ideal, but I dont know how to convert Pdf image to dwf. Please describe more clearly. Thanks very much.
To covert pdf to dwf
I open pdf file & go to print & slect 'Autodesk DWF Writer for 2D'(which gets automatically installed whe you install auotcad 2008 onward version in your computer) as printer and print so it creats dwf out of it. if it is multipage pdf select current page & print to dwf. repeat for each page of pdf.
Im using Acrobat 7.0 Pro, maybe it doesn't support that funtion. I Will try to on Ver. later. Thanks.
