TroutKing Posted August 18, 2009 Posted August 18, 2009 Hello I have pulled the following two routines off of the intent in an attempt to remove all the empty Text and Mtext strings in my drawings. The programs seem to work for Text but they do not work for MText. I am not sure why. I suspect the empty MText strings in my particular drawings possibly contain more than one space, but I’m not sure if that’s true or not. Can someone help me adjust one or both of these routines so that they will pick up and delete all empty MText strings no matter how many spaces they may contain? I would appreciate your help. (I apologize for not giving credit to the original authors but I don’t have that information. I have had these programs in my chickenscratch files and do not know who wrote them) Sub RemoveTextInPaperSpace() Dim elem As Object Dim found As Boolean For Each elem In ThisDrawing.PaperSpace ' With used so we don't have to reference our object by name With elem ' Check for EntityType by database name If (.EntityName = "AcDbText") Then If (.TextString = "") Or (.TextString = " ") Then .Delete found = True End If End If End With Next elem ' Clean up memory and release object Set elem = Nothing ' If we didn't find leaders, notify user If Not found Then MsgBox "No text found, or all have been removed", vbInformation End If End Sub - and [font=Arial][color=#232323][color=#232323][font=Arial]Sub NewString()[/font][/color] [font=Arial][color=#232323]Dim oEnt As AcadEntity[/color][/font] [font=Arial][color=#232323]Dim oBlock As AcadBlock[/color][/font] [font=Arial][color=#232323]For Each oBlock In ThisDrawing.Blocks[/color][/font] [font=Arial][color=#232323]If Not oBlock.IsXRef Then[/color][/font] [font=Arial][color=#232323]For Each oEnt In oBlock[/color][/font] [font=Arial][color=#232323]If oEnt.ObjectName = "AcDbMtext" Or oEnt.ObjectName = "AcDbText" Then[/color][/font] [font=Arial][color=#232323]If oEnt.TextString = "OldString" Then oEnt.TextString = "NewString"[/color][/font] [font=Arial][color=#232323]End If[/color][/font] [font=Arial][color=#232323]Next oEnt[/color][/font] [font=Arial][color=#232323]End If[/color][/font] [font=Arial][color=#232323]Next oBlock[/color][/font] [font=Arial][color=#232323]End Sub[/color][/font] [/color][/font] Thank you for the help, Mike Quote
bsamc2000 Posted August 18, 2009 Posted August 18, 2009 When checking I would use String.IsNullOrEmpty(tstString) I think this will check for a double space. Someone please correct me if I'm wrong. Quote
TroutKing Posted August 19, 2009 Author Posted August 19, 2009 Thanks for the input bsamc2000. I worked with your idea a bit but haven’t had any luck. I’ve now adjusted the code in order to run some tests on the attached drawing. It appears to work well for the empty Text strings but I’m still having problems getting it to recognize and adjust the empty MText strings. If I can get it to recognize and adjust the MText then I can work on putting this into a loop and cleaning it up. Can someone tell me why the code below won’t recognize empty MText strings? Sub RemoveTextInModelSpace() Dim elem As Object Dim TheEmptyTextString1 As String TheEmptyTextString1 = " " Dim TheEmptyTextString2 As String TheEmptyTextString2 = " " Dim TheEmptyTextString3 As String TheEmptyTextString3 = " " Dim TheEmptyTextString4 As String TheEmptyTextString4 = " " Dim TheEmptyTextString5 As String TheEmptyTextString5 = " " Dim TheEmptyTextString6 As String TheEmptyTextString6 = " " Dim TheEmptyTextString7 As String TheEmptyTextString7 = " " Dim TheEmptyTextString8 As String TheEmptyTextString8 = " " Dim TheEmptyTextString9 As String TheEmptyTextString9 = " " Dim TheEmptyTextString10 As String TheEmptyTextString10 = " " For Each elem In ThisDrawing.ModelSpace With elem If (.EntityName = "AcDbText") Or (.EntityName = "AcDbMText") Then If (.TextString = TheEmptyTextString1) Then .TextString = "1" elem.Update '.Delete ElseIf (.TextString = TheEmptyTextString2) Then .TextString = "2" elem.Update '.Delete ElseIf (.TextString = TheEmptyTextString3) Then .TextString = "3" elem.Update '.Delete ElseIf (.TextString = TheEmptyTextString4) Then .TextString = "4" elem.Update '.Delete ElseIf (.TextString = TheEmptyTextString5) Then .TextString = "5" elem.Update '.Delete ElseIf (.TextString = TheEmptyTextString6) Then .TextString = "6" elem.Update '.Delete ElseIf (.TextString = TheEmptyTextString7) Then .TextString = "7" elem.Update '.Delete ElseIf (.TextString = TheEmptyTextString8) Then .TextString = "8" elem.Update '.Delete ElseIf (.TextString = TheEmptyTextString9) Then .TextString = "9" elem.Update '.Delete ElseIf (.TextString = TheEmptyTextString10) Then .TextString = "10" elem.Update '.Delete End If End If End With Next elem Set elem = Nothing MsgBox "Complete" End Sub EmptyTextStringTestDrawing.dwg Quote
bsamc2000 Posted August 19, 2009 Posted August 19, 2009 This should work. Sub RemoveTextInModelSpace() Dim elem As Object For Each elem In ThisDrawing.ModelSpace With elem If (.EntityName = "AcDbText") Or (.EntityName = "AcDbMText") Then If Len(Trim(.TextString)) <= 0 Or Trim(.TextString) = "\pxqc;" Then .TextString = "X" .Update End If End If End With Next elem Set elem = Nothing MsgBox "Complete" End Sub Quote
TroutKing Posted August 19, 2009 Author Posted August 19, 2009 That worked very nicely! Thank you! I'm still not sure why I couldn't get it to pick up the MText but I suppose thats irrelevant at this point since the code you supplied works for the desired task. Thank you very much. I appreciate your help! Quote
TroutKing Posted August 19, 2009 Author Posted August 19, 2009 Any idea as to why I cant get rid of the 3 remaining empty MText strings in this drawing? ExtraneousText.dwg Quote
