OMEGA-ThundeR Posted August 19, 2009 Posted August 19, 2009 Hi, Autocad Map (2010) should be in the Civil 3d 2010 package. However Civil 3D 2010 is installed, but can't find anything that links to MAP. Is there an special shortcut to get in MAP or is there any other way to get there?. I got an tutorial to do something that fastens our work, but it seems to be for Autocad MAP. Since we have Civil 3D it should be there.... Anyone who can shed a light on this? Quote
NBC Posted August 19, 2009 Posted August 19, 2009 AutoCAD Map is a quite different product these days to Civil 3d Quote
OMEGA-ThundeR Posted August 19, 2009 Author Posted August 19, 2009 Well its for some functions that are only in MAP, so therefor i need to be in that program. However it doesn't show up in the menubar or workspaces and there is no shortcut for it like "Civil as Autocad" and that is what i need. Quote
chulse Posted August 19, 2009 Posted August 19, 2009 Load the MAPCLASSIC cui and you should have most of the MAP functionality. Full MAP is different from C3D as far as I know... Quote
OMEGA-ThundeR Posted August 19, 2009 Author Posted August 19, 2009 Thanks you very much. This should do it. Quote
rkmcswain Posted August 19, 2009 Posted August 19, 2009 Load the "Map 3D for Geospatial" workspace. Civil 3D is built on top of Map, so all the Map functionality should be there. If the command you need is not in that workspace, you may have to add it and save as your own workspace. Quote
OMEGA-ThundeR Posted August 20, 2009 Author Posted August 20, 2009 I can't find any workspace that is MAP related. At the workspace selection in de lowerright corner there is nog MAP workspace to be seen... Quote
rkmcswain Posted August 20, 2009 Posted August 20, 2009 What workspaces does it show, and what is the current main menuname (type in MENUNAME at the command prompt) Quote
