Missing Toolbar
I have a missing toolbar - UCS11
I can't find it in my CUI and It's not there when I right clikc the grey area. How would I get it back?
Cheers
Been messing around in the cui again haven't you? When you say "my cui" is that a custom cui you're referring to?
No not at all. I just went looking for that toolbar because I seem to be using the named UCS alot these days but I an't find it. It's on a work mates PC with the exact same version of ACAD?
And somehow UCSII has managed to fall off the list of standard AutoCAD toolbars. Hmmmm....very interesting.
Maybe I was messing months and months ago when I last cam here for help.
Anyway, where could it be?
Try this:
Enter -TOOLBAR at the command line. When prompted for the toolbar name, enter the name of the toolbar that you want to find. Next, you will be prompted for an option. The options are listed in brackets. Enter F for Float and Enter. The command line will now ask for a New Position (screen coordinates). Enter 500,500 (approximate center of the screen) and press Enter. When asked for the number of rows for the toolbar, accept the default value. With any luck the missing toolbar should reappear near the center of your screen. Relocate and resize as needed.
Did it work?
Make sure to type UCSII and not USC11. There is a difference.
Try this:
Did it work?
Already tried that, toolbar not found :(
Well I suppose you could try the Repair option or check to see if your Profile got messed up.
