I am using draworder as follow:
; ss is not empty!
(sssetfirst ss)
(command "_.draworder" ss "" "_F")
It works fine, doing what it is supposed to do. The only problem is that after I execute it, i received this message:
Unknown command "F". Press F1 for help.
It seems that it does not recognize the "_F" final token
I am in PAPER SPACE (may be this is the problem?!), and the objects en ss are also in PAPER SPACE
thanks...
I can't see an error in your code above, except that you may want to use (sssetfirst nil ss).
If you are still having problems - look into altering the draworder using VL. :)
I wrote this lisp for work. I personally use it all the time. You can try remaking it to fit your needs or just use it as is.
********************A different approach at DRAWORDER*********************
******************************By: ZRABOIN*********************************
(defun c:ndo( / cord goto adoc obj obj1 obj2 ent)
 (vl-load-com)
 (setq cord (vla-addobject
          (vla-GetExtensionDictionary
        (vla-get-modelspace
          (setq adoc (vla-get-activedocument
               (vlax-get-acad-object))))) "ACAD_SORTENTS" "AcDbSortentsTable"))
 (initget "1 2 3 4 5 6")
 (setq goto (cond ((getkword "\nWould you like to (1)-Bringtofront (2)-Sendtoback (3)-Sendbehind (4)-Bringabove (5)-SwapObjects (6)-Special ?: <bringtoFront> ")) ("1")))
 (cond
   ((and (= goto "1")
     (setq ent (mkar)))
    (vla-Movetotop cord ent))
   ((and (= goto "2")
     (setq ent (mkar)))
    (vla-Movetobottom cord ent))
   ((and (= goto "3")
     (setq ent (mkar)))
    (setq obj (entsel "\nSelect Reference Object: "))
    (setq obj (vlax-ename->vla-object (car obj)))
    (vla-Movebelow cord ent obj))
   ((and (= goto "4")
     (setq ent (mkar)))
    (vla-Moveabove cord ent obj))
   ((and (= goto "5")
     (setq obj1 (vlax-ename->vla-object(car(entsel))))
     (setq obj2 (vlax-ename->vla-object(car(entsel)))))
    (vla-SwapOrder cord obj1 obj2))
   ((and (= goto "6")
     (setq obj (mksar)))
    (vla-setRelativeDrawOrder cord obj)
 (vla-regen adoc acActiveViewport)
;******************************Make Array**********************************************************************
(defun mkar ( / ss arobj)
 (if (setq ss (ssop))
 (setq ss (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
   arobj (vlax-safearray-fill (vlax-make-safearray vlax-vbobject (cons 0 (- (length ss) 1))) ss)))
;******************************Make Array Multiple Selections**************************************************
(defun mksar ( / ss s1 arobj)
 (while (setq s1 (ssop))
   (setq ss (append (vl-remove-if '(lambda (z) (member z ss)) (vl-remove-if 'listp (mapcar 'cadr (ssnamex s1)))) ss)))
 (setq    arobj (vlax-safearray-fill (vlax-make-safearray vlax-vbobject (cons 0 (- (length ss) 1))) (mapcar 'vlax-ename->vla-object ss)))
;******************************Selection Set Options************************************************************
(defun ssop ( / ssmeth s1 ss)
 (initget "1 2 3 4")
 (setq ssmeth (cond ((getkword "\nSelect by: (1)-Specified Objects (2)-Layer (3)-Blockname (4)-Similar - <Specified Objects> : ")) ("1")))
 (setq curt (getvar "ctab"))
 (cond ((= ssmeth "1")
    (setq ss(ssget)))
   ((= ssmeth "2")
    (if (setq ss (entsel "\nSelect an object on the layer you want: "))
      (ssget "X" (list (cons 410 curt) (cons 8 (cdr (assoc 8 (entget (car ss)))))))))
   ((= ssmeth "3")
    (if (setq ss (entsel "\nSelect a block: "))
      (if (= (cdadr (setq ss (entget (car ss)))) "INSERT")
        (setq ss (ssget "X" (list (cons 410 curt) (cons 2 (cdr (assoc 2 ss)))))))
   ((= ssmeth "4")
    (if (setq ss (entsel "\nSelect an object: "))
          (setq s1 (cons 2 (cdr (assoc 2 ss))))
          (setq s1 (cons 0 (cdr (assoc 0 ss)))))
        (setq ss (ssget "X" (list s1 (cons 410 curt) (cons 8 (cdr (assoc 8 ss)))))))
