drawing status bar/tray
yrnomad
Like this?
(defun c:SpkON ( )
 (vl-load-com)
 (if (not *spk*)
     (setq *spk*
       (vlr-command-reactor nil
         (list
           (cons :vlr-CommandWillStart 'Speak))))
     (princ "\n<< Reactor Initiated >>"))
   (princ "\n<< Reactor Already Running >>"))
 (princ))
(defun Speak (Reac Args / Vce)
 (if (not
       (wcmatch
         (strcase (car Args)) "PAN,ZOOM"))
     (setq Vce (vlax-create-object "Sapi.SpVoice"))
     (vlax-invoke Vce "Speak"
       (strcat (car Args) " commmand started") 0)
     (vlax-release-object Vce)))
 (princ))
(defun c:SpkOFF ( )
 (if (and *spk* (vlr-added-p *spk*))
     (vlr-remove *spk*)
     (setq *spk* nil))
   (princ "\n<< Reactor Not Running >>"))
 (princ))
  • Replies 57
  • Lee Mac
    22
  • alanjt
    12
  • MarcoW
    7
  • StevJ
    5
Posted Images
It is possible to get AutoCAD to 'speak' to the user
Yes, it's possible
Here's a `bad joke':
(or *BadJoke*
   (setq *BadJoke*
                               '((:vlr-commandWillStart . BadJokeCallBack))
(defun BadJokeCallBack (rea cmd)
 (setq sapi (vlax-create-object "Sapi.SpVoice"))
 (vlax-invoke sapi "Speak" (car cmd) 0)
 (vlax-release-object sapi)
I'm too newbie in this forum to be allowed to give you the link to a long thread at TheSwamp, but you can search in the LISP forum for "Patrick_35 speak".
haha - you just want something to impress your colleagues :D
Well, I'm not sure there are many things that aren't obvious, but I suppose you could change the setting of the sys var: MTJIGSTRING :)
Not only for impressing... when one is drawing 5 days a week it's nice to mess around with the tools.
@ Lee:
That's what I meant, fun with talking autocad...:?
I'll sneaky enhance my collegues autocad... like to see the face!
@ Gile:
I can't follow your code, is the routine complete?
When I was new I had the same prob with adding links or sending PM.
Maybe you can explain where to search?
@ Gile:
As I said, it's just a `bad joke' if you copy/paste the code #42 to the command line of somebody in your office.
He (or you) should have to copy/paste the code #44 to stop AutoCAD announcing every command he launches.
You can find the trhead I said in the LISP forum of TheSwamp searching for "Patrick_35 speak".
Or maybe Lee post the link...
Lee, I didn't saw your post before posting mine, sorry...
Lee, I did saw your post before posting mine, sorry...
Not a problem Gile 8)
Here is the link:
http://www.theswamp.org/index.php?topic=14549.0
  • 2 weeks later...
Command:
-VIEW Enter an option [?/Orthographic/Delete/Restore/Save/Ucs/Window]: O
Enter an option [Top/Bottom/Front/BAck/Left/Right]:
What will be Diesel macro to display current view i.e: Top/Bottom/Front/BAck/Left/Right
in bottom corner screen beside: text size, dim scale etc.?
