I have this lisp I made from a templete someone give why won't it work?
(defun c:seal ()
  (initget "Gene Jason Lynn Paul Stuart Todd"
(setq UsrName (getkword "\nEnter name [G]ene,[J]ason,[L]ynn,[P]aul,[s]tuart,[T]odd: ")
(command "-LA" "" "ON" "" "XTB|PE-GENE" "" "XTB|PE-JASON" "" "XTB|PE-LYNN" "" "XTB|PE-PAUL" "" "XTB|PE-STUART" "" "XTB|PE-TODD" "THAW" "XTB|PE-GENE" "" "XTB|PE-JASON" "" "XTB|PE-LYNN" "" "XTB|PE-PAUL" "" "XTB|PE-STUART" "" "XTB|PE-TODD" "" "");;run this for all users first
(cond
   ((= Usrname "Gene")
       (command "-LA" "" "OFF" "" "XTB|PE-JASON" "" "XTB|PE-LYNN" "" "XTB|PE-PAUL" "" "XTB|PE-STUART" "" "XTB|PE-TODD" "THAW" "" "XTB|PE-JASON" "" "XTB|PE-LYNN" "" "XTB|PE-PAUL" "" "XTB|PE-STUART" "" "XTB|PE-TODD" "" "");;GENE'S commands
   ((= Usrname "Jason")
       (command "-LA" "" "OFF" "" "XTB|PE-GENE" "" "XTB|PE-LYNN" "" "XTB|PE-PAUL" "" "XTB|PE-TODD" "THAW" "XTB|PE-GENE" "" "XTB|PE-LYNN" "" "XTB|PE-PAUL" "" "XTB|PE-STUART" "" "XTB|PE-TODD" "" "");;JASON'S commands
   ((= Usrname "LYNN")
       (command "-LA" "" "OFF" "" "XTB|PE-GENE" "" "XTB|PE-JASON" "" "XTB|PE-PAUL" "" "XTB|PE-STUART" "" "XTB|PE-TODD" "THAW" "XTB|PE-GENE" "" "XTB|PE-JASON" "" "XTB|PE-PAUL" "" "XTB|PE-STUART" "" "XTB|PE-TODD" "" "");;LYNN'S commands
   ((= Usrname "PAUL")
       (command "-LA" "" "OFF" "" "XTB|PE-GENE" "" "XTB|PE-JASON" "" "XTB|PE-LYNN" "" "XTB|PE-STUART" "" "XTB|PE-TODD" "THAW" "XTB|PE-GENE" "" "XTB|PE-JASON" "" "XTB|PE-LYNN" "" "XTB|PE-STUART" "" "XTB|PE-TODD" "" "");;PAUL'S commands
   ((= Usrname "STUART")
       (command "-LA" "" "OFF" "" "XTB|PE-GENE" "" "XTB|PE-JASON" "" "XTB|PE-LYNN" "" "XTB|PE-PAUL" "" "XTB|PE-TODD" "THAW" "XTB|PE-GENE" "" "XTB|PE-JASON" "" "XTB|PE-LYNN" "" "XTB|PE-PAUL" "" "XTB|PE-TODD" "" "");;STUART'S commands
   ((= Usrname "TODD")
       (command "-LA" "" "OFF" "" "XTB|PE-GENE" "" "XTB|PE-JASON" "" "XTB|PE-LYNN" "" "XTB|PE-PAUL" "" "XTB|PE-STUART" "" "THAW" "XTB|PE-GENE" "" "XTB|PE-JASON" "" "XTB|PE-LYNN" "" "XTB|PE-PAUL" "" "XTB|PE-STUART" "" "");;TODD'S commands
It won't even run it, it will load it but not when I type seal it errors.
Thanks in advance for any help in the future.
Just a very quick glance, and I may be wrong but am not going to check right now, do you have enough ) and in the right place to close the ( ??
from LCE's reply, just add the red parenthesis in your lisp file
(initget "Gene Jason Lynn Paul Stuart Todd")
(setq UsrName (getkword "\nEnter name [G]ene,[J]ason,[L]ynn,[P]aul,tuart,[T]odd: "))
ok that works now when I select a name it runs the command for them is saying -La unknown command does anyone know why?
Sorry, I can not help you with this as I am not a big fan of lisp and won't spend the time looking at it now.
However, if you are not particularly fussed about having it in lisp, I can do it in VBA or VB.NET for you.
Let me know if you want that, if not, I am sure someone else will be along soon who does like lisp.
Cheers
EDIT: See, there you go, someone even beat me to it.
now it does not except the on in layers
try this format:
(defun c:seal ()
(setq UsrName (getkword "\nEnter name [G]ene,[J]ason,[L]ynn,[P]aul,[s]tuart,[T]odd: "))
(command "_.layer" "" "ON" "" "XTB|PE-GENE,XTB|PE-JASON,XTB|PE-LYNN,XTB|PE-PAUL,XTB|PE-STUART,XTB|PE-TODD" "THAW" "XTB|PE-GENE,XTB|PE-JASON,XTB|PE-LYNN,XTB|PE-PAUL,XTB|PE-STUART,XTB|PE-TODD" "");;run this for all users first
(cond
   ((= Usrname "Gene")
       (command "_.layer" "OFF"  "XTB|PE-JASON,XTB|PE-LYNN,XTB|PE-PAUL,XTB|PE-STUART,XTB|PE-TODD" "THAW" "XTB|PE-JASON,XTB|PE-LYNN,XTB|PE-PAUL,XTB|PE-STUART,XTB|PE-TODD" "");;GENE'S commands
Its works is there any way to make it run faster.
thanks for everything!
The problem looks like it is in your COMMAND line. After doing "-la" you have "" which tells Autocad to hit enter/space, which ends the layer command. You also have one after "ON" and between all your layer names, which are unnecessary. Also, you want to call "-layer". When using autocad commands in LISP, you have to call the complete command name as LISP doesn't recognize aliases set up in your ACAD.PGP file.
To make it a little faster, you might want to turn CMDECHO off before running all your COMMANDs.
is there a wa to turn mult layers off like maybe a comma in between them instead of "off" "layer" "off" "another layer"?
  • 4 months later...
You can turn on, off, freeze, thaw multiple layers at a time by using wildcards like "?" or "*" in your layer names. I'd suggest something like:
(command "_layer" "T" "XTB*" "OFF" "XTB*" "ON" "XTB|PE_PAUL" "")
for Paul's commands.
